Miata Engine Swap Help
PS, before I forget. There are the 2 coolant lines going to the heater core from the motor. DO NOT DISCONNECT THEM AT THE FIREWALL! There are copper tubes under there and they bend really easy! The only real way to remove those lines is to slice them and peel them back. That said, they really need to be disconnected from the engine if you want to re-use them. They are dealer only parts and more than likely not on the shelf.
94mx5 wrote:I could likely put in an hour or two on Sunday. I am already booked for Saturday...
Any tools needed or will everything needed be there? I prefer not to bring my tools and try to sort them out afterwards.
We should have everything we need but if all else fails, Harbor Freight is only a few miles away.
- RedRoadster
There's a few 17mm bolts/nuts as well.
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Flyin' Miata stuff:
That's what I keep reading on miata.net. People say this is the easiest car they've ever worked on.
deepSpeedMS3
PM'd you. I should be there in the afternoon. I'll make sure to call you before I head out so I don't drive an hour for nothing.
If anyone has an extra floor jack and small jack stands we might need them. More for for my Miata but could come in handy in the swap. Part of the Monster Miata build is to send the K member and hubs back to be modified and this requires taking off the entire suspension. I have one jack but need two to lower the car onto the dollies. I already have the front suspension off but can't get the back off without another jack. Let me know.
Users browsing this forum: Baidu [Spider], Google [Bot] and 90 guests
