My First Carnage with the Speed!!!
Postby tbot » Wed Jan 20, 2010 9:14
Long story, but had an internal error when trying to post...
Check it out here:
http://forum.mazda6club.com/index.php?showtopic=120120
Postby bmwzoom » Wed Jan 20, 2010 9:14
Bummer dude! At least I am (somewhat) coming to your rescue tomorrow!
rush24
Postby rush24 » Wed Jan 20, 2010 9:14
That sucks man....Hope the dealership will cover it...If not...Hope its cheap to repair...
2007 Black CX7
Apexcone Raptor 6000k HID...
3" DP back Exhaust System
SURE Motor Mount...
[/color]
I would think, its only a couple of bolts, but I guess there's been lots of problems with these, so I'm going to try and use that for my benefit. But I've heard they have to drop the entire diff to get it done. Oh well, we shall see!
Postby erod550 » Wed Jan 20, 2010 9:14
Yep, I've heard lots of MS6 people talking about problems with the rear diff mounts. It's usually one of the first things they upgrade.
I have too, but this wasn't the mount, it was the bolts to the mount that broke. I think even if I had upgraded that mount I would be in the same situation cause it was the bolts. Ah well, it'll be looked at tomorrow, and hopefully fixed!
Rich
Postby Rich » Wed Jan 20, 2010 9:14
Exact same thing happened to me. The dealer had no problem repairing it under warranty. Mazda has made stronger replacement bolts specifically to address this issue.
tbot wrote:I have too, but this wasn't the mount, it was the bolts to the mount that broke. I think even if I had upgraded that mount I would be in the same situation cause it was the bolts. Ah well, it'll be looked at tomorrow, and hopefully fixed!
Ah ok. I hadn't looked into specifics because I don't have a rear diff. :P
rmeeker13
Postby rmeeker13 » Thu Jan 21, 2010 9:14
I shredded my rear diff mount bolts last summer...was covered under warranty!
Eclipse
Postby Eclipse » Thu Jan 21, 2010 9:14
tbot is out of warranty coverage:o
Powerstroke 6.0
Postby Stealth01 » Thu Jan 21, 2010 9:14
I'll have to check and see if they used the upgraded bolts on my rear diff mount when they replaced it. I'm hoping they did....
Postby erod550 » Thu Jan 21, 2010 9:14
At least the bolts should be cheap, assuming nothing else broke due to the bolts popping out.
Postby tbot » Thu Jan 21, 2010 9:14
Rich wrote:Exact same thing happened to me. The dealer had no problem repairing it under warranty. Mazda has made stronger replacement bolts specifically to address this issue.
Well thats good to know!!! I had even told the service writer at the dealer about this and they just gave me a blank look haha, so hopefully the techs know more about it. Still waiting to hear back from them, dropped it off at 7 this morning.
tbot wrote:Well thats good to know!!! I had even told the service writer at the dealer about this and they just gave me a blank look haha, so hopefully the techs know more about it. Still waiting to hear back from them, dropped it off at 7 this morning.
If they don't help you, bring it down to Bob Penkhus Mazda in the Springs. You'd have to have it towed, but they'd fix you up. Still in warranty?
well according to mazda it has a 50k mile warranty for the drive train, so I should be good. Either way, I have a warranty thru penkhus (where i bought it from) thats extended.
