Cold Air Intake Question For Ms6
Punisher
Postby Punisher » Thu Nov 08, 2007 9:14
I'm looking to buy a cold air intake for the MS6 I have and would like a splash guard. Does anyone have any information to a business locally I could go buy one at or recommend a brand that i could buy online? Thank guys.
firestoned
Postby firestoned » Thu Nov 08, 2007 9:14
I would say that a splash guard isnt needed for the MS6 because of how its protected in the fender....unless you are traversing through rivers or deep puddles....and in that case, I would do a SRI rather than a CAI
bobopud
Postby bobopud » Thu Nov 08, 2007 9:14
I'm pretty sure that Cpe makes one, I think it is called a pre air filter. Other then that I don't know who makes one.
I've been driving around without one for a little over a year and have never had an issue with sucking up anything through the filter. Even water. As long as you are careful there shouldn't be an issue. Of course it never hurts to go the extra mile either.
GoToTheJoe
Postby GoToTheJoe » Thu Nov 08, 2007 9:14
I bought mine from autoanything.com for $23.95 (no tax, free shipping). It is an Injen Hydroshield. I believe the correct size is the medium. I never had any problems with water either but a $24 insurance policy seemed to make sense
http://www.autoanything.com/air-filters/65...x?from_search=1
--brian
2006 MazdaSpeed6 GT ** Whitewater Pearl Mica ** 5Zigen Pro Racer ZR+520 Wheels - Ceramic Bronze ** Navigation ** Integrated Sirius Radio ** Black and White Leather Interior ** 18% window tint ** Clear Bra ** Moonroof ** Wheel Locks ** MazdaSpeed CAI ** VG Sharkfin ** CF MazdaSpeed License Plate Holder ** Cargo Net ** Firestone Firehawk Wide Oval Indy 500 225/45r/18 ** Lamin-x Charcoal Headlight Protector **
Punisher
Well I went to Import Auto Parts off of Illiff today. I bought an OEM cold air intake along with a valve that goes inside and acts as an internal splash guard. The valve won't allow water in but if it does get sucked up do to a flooded street along the curb or something the valve won't allow water in. By the way the OEM intake is chrome and I am not sure if I will want to keep it. They had red ones but were on back order and didn't want to wait. If I don't like it I may order the red and turn around and sell the chrome one along with the valve inside. If anyone would possible be interested let me know. First come first serve. Of course I will let you all know more later. Trying to figure out if I want to keep a red/black theme going or not. maybe red and chrome...who knows. [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/61064996.gif[/img] Cheers!
Postby Colombia28 » Thu Nov 08, 2007 9:14
By "OEM" you mean a mazdapseed cold air intake?
Postby SpeedRacer » Thu Nov 08, 2007 9:14
IF this is like the AEM Bypass DO NOT USE IT. Please take a picture of this tube? The problem is with Turbo's they get sucked in by the force and literally destroy your car.
If it looks anything like this do not use it.
Just to clarify what Josh said; its not the piece itself that gets sucked in, its the foam in the center, its been known to break up into pieces under pressure.
Postby SpeedRacer » Fri Nov 09, 2007 9:14
Exactly thank you Andrew [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/smile.gif[/img]
arctic_blue83
Postby arctic_blue83 » Fri Nov 09, 2007 9:14
<div class='quotetop'>QUOTE (SpeedRacer @ Nov 8 2007, 10:09 PM) [url=index.php?act=findpost&pid=10122]<{POST_SNAPBACK}>[/url]</div>
Image[/b]
Good call Josh!
In a case where your motor isn't damaged, the fins on the compressor wheel of your turbo are destroyed. This is due to the extra vacuum effect coming from the compressor housing, which is obviously spun by the turbine housing.
You can check this out on AEM's website:
http://www.aempower.com/ViewCategory.aspx?CategoryID=20
"...The AEM Air Bypass Valve is C.A.R.B. exempt on AEM Cold Air induction systems only and is NOT for use on forced induction vehicles..."
^^^That pretty much sums it up lol.
Punisher
Postby Punisher » Sun Nov 11, 2007 9:14
yep your right...typo error on my part. It's an AEM cold air intake. I pick it up tomorrow. I will look and see if that is the part. If it is I will post here for sale for a regular 6 or 3 to use. If not i will take a pic and post it here. Thanks for the info...good to know.....would have been pissed if that happened. Well I am off to the mountains today....see how this car handles the runs. Talk to you all again soon and thanks once again for the info.....glad I joined.
Bruce
