*DarthRX8*
Postby *DarthRX8* » Mon Nov 16, 2009 9:14
I thought this was a real story until I read the rectum part, LOL! Good one :lol:
Postby GR-8 » Mon Nov 16, 2009 9:14
LMAO Guido that's a good one! :lol:
MazdaGurl
Postby MazdaGurl » Thu Nov 19, 2009 9:14
During a recent password audit, it was found that a blonde was using the
following password: MickeyMinniePlutoHueyLouieDeweyDonaldGoofySacramento
When asked why such a long password, she said, "I was told that it had
to be at least 8 characters long and include at least one capital."
Postby erod550 » Thu Nov 19, 2009 9:14
well at least she knew that Sacramento was the capital lol.
Postby tsx_guy » Thu Dec 10, 2009 9:14
Bill worked in a pickle factory. He had been employed there for a number of years when he came home one day
to confess to his wife that he had a terrible compulsion.
He had an urge to stick his penis into the pickle slicer. His wife suggested that he should see a sex therapist to talk about it, but Bill said he would be too embarrassed. He vowed to overcome the compulsion on his own.
One day a few weeks later, Bill came home and his wife could see at once that something was seriously wrong.
'What's wrong, Bill?' she asked.
'Do you remember that I told you how I had this tremendous urge to put my penis into the pickle slicer?'
'Oh, Bill, you didn't' she exclaimed.
'Yes, I did.' he replied.'My God, Bill, what happened?'
'I got fired.'
'No, Bill. I mean, what happened with the pickle slicer?'
'Oh...she got fired too.'
Postby tsx_guy » Wed Dec 16, 2009 9:14
A man, whose level of drunkenness was bordering on the absurd, stood up to leave a bar and fell flat on his face.
"Maybe all I need is some fresh air," thought the man as he crawled outside. He tried to stand up again, but fell face first into the mud.
"Screw it," he thought. "I'll just crawl home."
The next morning, his wife found him on the doorstep asleep.
"You went out drinking last night, didn't you?" she said.
"Uh, yes," he said sheepishly. "How did you know?"
"You left your wheelchair at the bar again."
LaginWagon
Postby LaginWagon » Wed Dec 16, 2009 9:14
With all this talk about winter wrenching it seems appropriate to give a short explanation of the uses of some of the basic tools!
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, shit!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race...
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. - especially useful for slicing work clothes, but only while in use.
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling "Son of a bitch" at the top of your lungs. It is also, most often, the next tool that you will need.
__________________
Postby iani1.1 » Wed Dec 16, 2009 9:14
haha the son of a bitch tool. i have a set of those, i also have a son of a bitch tool box with it.
LaginWagon
Postby LaginWagon » Thu Dec 17, 2009 9:14
[url=[URL=http://s84.photobucket.com/albums/k27/S4poor14/Various/?action=view¤t=JBSklip.flv]Image[/url]]Image[/URL]
Postby kingtut » Thu Dec 17, 2009 9:14
Everybody does love the smell of their own brand, right? lol
Postby tsx_guy » Thu Dec 17, 2009 9:14
kingtut wrote:Everybody does love the smell of their own brand, right? lol
i beg to differ... :huh:
Postby kingtut » Sat Dec 19, 2009 9:14
Postby tsx_guy » Sun Dec 20, 2009 9:14
wow tut can I have my 45 seconds back? :D
MazdaGurl
Postby MazdaGurl » Tue Jan 19, 2010 9:14
Gotta love Craigslist. There's a section under personals called "Rants and Raves." Spend a few minutes there and you'll roll your ass off. Here's an example.
Post #1: (http://denver.craigslist.org/rnr/1559808782.html)
i have never in my life come across a message board that made an entire city look like the biggest bunch of inbred mountain trailer trash you guys do realize that your spam and hateraid make you look like your state is full of fuckin retards and closet queers right? denver must be full of budweiser and moonshine drinkin sister fuckin closet cases as much as you morons talk about dicks and blacks lay off the crystal meth and go get some sleep you fucking pieces of mountain goat shit and shut the fuck up already
Response: (http://denver.craigslist.org/rnr/1559939265.html)
HEY!!! We may be inbred queers and racist, spamming cracker lunatics and meth addicted niggers, but we fucking drink Coors around these parts. Fuck Budweiser!
Postby tsx_guy » Tue Jan 19, 2010 9:14
I see you found my c/l rant Angie. :lol:
