Tranny on MS3
sookiespeed
Tranny on MS3
Postby sookiespeed » Mon Nov 09, 2009 9:14
So...driving the Speed saturday nearing Bijou on I25 north and start to hear what sounds like rocks in a tin can. Pull off Fontenaro exit shut off the car...turn it back on with the clutch in...no noise...neutral let out the clutch...DAMN LOUD.....no 1st gear. i've had issue with the car and 1st gear since i got it. Impossible to get into first unless at a complete stop ONLY when cold...when warm it will go into 1st just fine between 3 and 5 MPH...WTF....dealer still looking at it.
Gave me a 2008 3 sedan with auto for loaner..not complaining its free but what a dog...no offense to standard 3 owners just spoiled by my speed
Postby bellalyssa » Mon Nov 09, 2009 9:14
Did you buy the car new? Not being able to get it into gear when it's cold outside is normal-ish. Everything works a bit better when it's all warmed up.
I hope you get your speed back soon!
Postby tbot » Mon Nov 09, 2009 9:14
That sux, I hope everything goes ok at the dealer!!! And yeah, I know how slow those 3 autos are, I used to have one (now you know why I switched to a speed!)
Postby bmwzoom » Mon Nov 09, 2009 9:14
I don't have any issues with noises ((Knock on wood)). I do notice it is hard for me to downshift into first when the engine is cold though, I am assuming that just may be true for all MS3's when they are cold.
Good luck with the fix, I will be interested in hearing what the dealership has to say about this...
Postby chickenwafer » Mon Nov 09, 2009 9:14
when was the last time the transmission fluid was changed?
Postby bmwzoom » Tue Nov 10, 2009 9:14
chickenwafer wrote:when was the last time the transmission fluid was changed?
It's an '09! Does it need to be done so soon??
Postby chickenwafer » Tue Nov 10, 2009 9:14
Oh I didn't notice it was 09...if it has over 35,000 miles it should be done, however
Users browsing this forum: No registered users and 209 guests
