Another stupid question
Postby kingtut » Thu Nov 05, 2009 9:14
I haven't seen this discussed anywhere yet. So when I select the floor, defrost, or floor/defrost mix- my a/c compressor goes on.
Does anyone else have this problem and find it as annoying as I do?
Postby tsx_guy » Thu Nov 05, 2009 9:14
I believe this is normal. Part of the defrost process requires use of the A/C, but no I can't explain why.
I know this same behavior happens in our Civic.
Postby TheNewBlack » Thu Nov 05, 2009 9:14
Same thing happens in my WRX....when its freezing out it seems to make no sense.
Postby GR-8 » Thu Nov 05, 2009 9:14
IDK Havn't noticed that. DO you have the A/C button on? Not like I can help you there cause my car is getting a touch up with Dr. Dean. 1 more week. I hope.
Postby I`m Batman » Thu Nov 05, 2009 9:14
I believe it uses the A/C to dehumidify the air so your windows won't fog up.
Interesting. At first, I thought it was a problem that needed fixing. But upon further research, it does seem to be happening by design. That's odd that Honda and Subura does this too.
I don't know, it just seems retarded to me:huh:.
Postby Number2 » Thu Nov 05, 2009 9:14
kingtut wrote:Interesting. At first, I thought it was a problem that needed fixing. But upon further research, it does seem to be happening by design. That's odd that Honda and Subura does this too.
Sometimes retarded just makes sense. But be careful not to go full retard.
MazdaGurl
Postby MazdaGurl » Thu Nov 05, 2009 9:14
You'd actually be surprised how often the compressor runs. Tbot found out exactly which times it runs. Hopefully he'll log in soon and be able to share his profound knowledge with us...
Number2 wrote:Sometimes retarded just makes sense. But be careful not to go full retard.
What poem is that from? Is that James Joyce?
MazdaGurl wrote:You'd actually be surprised how often the compressor runs. Tbot found out exactly which times it runs. Hopefully he'll log in soon and be able to share his profound knowledge with us...
:741ccad5::blink:
CWPMS3
Postby CWPMS3 » Thu Nov 05, 2009 9:14
I`m Batman wrote:I believe it uses the A/C to dehumidify the air so your windows won't fog up.
I'll second that. It's used to dehumidify the air.
RedRoadster
Postby RedRoadster » Thu Nov 05, 2009 9:14
Everybody knows you never go full retard.
But yes, the a/c is supposed to kick in during defrost in order to clear the windows faster.
Does it make common sense, especially in the winter? No.
Does it work? yes. Faster than waiting for the heater to warm up.
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
Postby chickenwafer » Thu Nov 05, 2009 9:14
Air conditioning works by pulling moisture out of the air, so it prevents fogging of your windows. It's how A/C works
Eclipse
Postby Eclipse » Thu Nov 05, 2009 9:14
the compressor runs when the a/c is on, the defrost, the floor, and/or any combination of those
Powerstroke 6.0
there's no such thing as a stupid question tut, just stupid people. 8D
Users browsing this forum: Bing [Bot] and 149 guests
