Grounding
Postby RX-7 Chris » Thu Jul 09, 2009 9:14
it's a 2003
Postby tsx_guy » Thu Jul 09, 2009 9:14
my advice chris...get a new car....for your lady....
The car is just fine for now and only has about 62k on it.
Postby AIM WO4 » Thu Jul 09, 2009 9:14
I think that would have a Throttle Position Sensor... It is probably drive by wire, so theroretically a ground would help.
it does have a TPS but why does it also look like it has 2 cables to the TB?
the engine looks like this: http://photos.ebizautos.com/used-2003-saturn-l200-basetrim-6834-3810820-10-640.jpg
chris if that was a horse, I would shoot it.
a saturn with a slush box and 62k miles . get some NOS chris...
Hard to tell from the pic. Just check it to see if you have metal to metal contact from the TB to ground anywhere. Cables to the TB don't necessarily have to touch ground.
I'm sure it would probably help, the intake on this thing is plastic, I guess to go with the rest of the car.
Right... So no ground through the intake... Probably nothing through the linkage, as it may go from the TB, through a firewall to the rubber accelerator pedal.
RX-7 Chris wrote:I'm sure it would probably help, the intake on this thing is plastic, I guess to go with the rest of the car.
