Painter needed
Painter needed
I am gonna get the sides of my hood painted white and my roof painted black. any ideas of where to go? i'm hoping to keep it under 400-500 bucks
- hotthatch93
i think it just needs to be clean. idk i might wind up doing vinyl, i don't really wanna pour money into paint. i would clay bar it before getting the vinyl layed prob. is jimmy in greece? were did he get his vinyl done? or is that paint?
Why don't you do it your self using Dupli- Colors Paint shop. Everything I watch on TV and seen on the net says that it is fairly easy and could be done for probably $250. This is how I am going to paint my Miata and have done some research into the system.
Cheap HPLV Gun-$65
Paint shop primer- $19
Paint shop Color- $38 (one can of white and one can of black)
Paint shop Clear- $19
Masking an paint suplies-$45
That is really all you need and you can do it in your garage. The system is a two stage lacquer that dries very quickly (no baking) and has no recoat window. Lacquer is not as durable as modern enamel paints but will work very well in your application. I am not sure how the colors will match but you might be able to do that at a paint shop.
Cheap HPLV Gun-$65
Cesaros
coloskydiver wrote:Why don't you do it your self using Dupli- Colors Paint shop. Everything I watch on TV and seen on the net says that it is fairly easy and could be done for probably $250. This is how I am going to paint my Miata and have done some research into the system.
Cheap HPLV Gun-$65
yikes, painting a $500 carbon fiber hood yourself? thats a huge OOPS if you accidentally goof somthing.
