Hi I'm new! Well my car is!
Postby SpeedRacer » Wed Jun 03, 2009 9:14
My car wants to say hello to everyone!
The rims will be sold shortly, hopefully lol.
Anyways this is the stats on the car..
2003 GLI - 24v 2.9L VRT STG III
STG I installed by EIP in Maryland @ 1,200 mi
STG III Engine professionally built @ 39,900 mi
Current Mileage: 51,089mi (as of December 23rd, 2008)Engine
6 Speed manual transmission
Engine Bored and Stroked to 2.9L
Turbonetics "Ceramic Ball-Bearing" t04b turbocharger (brand new w/ engine build)
JE Forged Turbo Pistons (Low Compression)
Eurospec 4340 Forged Lightweight Connecting Rods
60 lbs/hr. (630cc/min) Hi-Impedance Large Injectors
Short Ram K&N Intake
High Volume, High Efficiency Front Mount Intercooler
Turbosmart Manual Boost Controller
Stainless Steel Dump Tube
Custom Fabricated Test Pipe (removed Catalytic Converter)
*High Volume Catalytic Converter is boxed and available
*Post cat 02 sensor mod installed
EIP Stage III Engine Management (utilizing 60lb injectors)
EIP 2.5in full SS dual tip exhaust
EIP 2.5in down pipe
EIP Ultra high grade stainless steel exhaust manifold
EIP High Strength / Low Vibration Motor Mount
EIP Strut Caps
Fully coated mandrel bent piping set
Classic Greddy TYPE "S" Blow Off-Valve
New OEM Oil Pump & Water Pump
Stage II Bosch Upgraded Fuel Pump
Suspension & Wheels
19in Axis Mod se7en rims (w/ brand new center-caps 4/3/08)
Front Tires: Nexen N3000 - low pro. (good tread as of 12/23/08)
Rear Tires: Hankook Ventus k104 Sport - low pro. (good tread as of 12/23/08)
Eibach Pro Springs (1.5in drop)
Eibach Pro Dampeners
Brembo drilled & slotted rotors
Hawk Performance Ceramic brake pads
Audio
JBL 1500-Watt Amplifier
Dual 12in Pioneer Premier subs in closed box
Rockford Fosgate 1-Farad Capacitor
Kenwood Excelon 817dvd w/ 5.1 surround sound & remote control
Alpine single-DIN center channel 5.1 surround sound speaker
Pyramid 160-Watt Amp (dedicated for alpine center speaker)
iPOD to Kenwood DVD touch screen interface device
Monsoon Speakers & Amplifier
Security
Viper Alarm System
Two-way pager/transponder with half-mile range
Glass breakage alarm module
Shock sensor alarm module
Remote window roll-up/down module
Remote start & turbo-timer module (Needs Install - Plugs into Viper System)
Interior
Center Steering Column VDO Boost gauge (dash color matched)
OEM Snap-in Brushed Aluminum Dash Kit (only center console)
GLI Sport Bucket Seats (dual tone - textured cloth)
Front/Rear Heavyweight Monster Mats
OBDII Engine Code Scanner
Exterior
Custom Eurogear Carbon/Kevlar Bowser Hood (Black & Red tight weave)
*Hood sides painted tornado red to line up with grill
*Update 8/6/08 Put Stock Hood/Grill Back on
*Update 12/22/08 Carbon-Bowser Hood - SOLD
Kamali Badge-less grill
Clear Side Markers
Tinting by EIP
Shaved Trunk VW Emblem
De-badged all trunk lettering
Solid Trunk fitted with dynamat extreme (sheets and foam filler)
2005 red/clear OEM tail lights
Molded Rear Bumper / Quarter Panel
Molded Front and Rear valiances
Dubtechnik Side Skirts (brand new & unpainted sitting in garage / included)
Custom Front Bumper (cut/molded to show intercooler)
Will also be retinted to 18% on all windows and 45% on front window.
Anyone interested in any of the stereo equipment make an offer!
Postby kingtut » Wed Jun 03, 2009 9:14
Nice! Congrats Josh:D
Postby tsx_guy » Wed Jun 03, 2009 9:14
uh...this is mazdaclub...vdub club is down the street....i thought you were looking at a subie?
Postby RX-7 Chris » Wed Jun 03, 2009 9:14
nice car
Postby Ranger » Wed Jun 03, 2009 9:14
Nice find. GLIs are great fun, there's nothing quite like the feel of the VR6 engine.
GTConversion
Postby GTConversion » Wed Jun 03, 2009 9:14
45% on the front window?
Seriously?
GTConversion wrote:45% on the front window?
Seriously?
Um yeah... Look at the pics of my white speed3. Tell me if you can tell its tinted to 45%.
Its really not that bad. Ask anyone who has seen my car or been inside it you can't tell its there.
Ranger wrote:Nice find. GLIs are great fun, there's nothing quite like the feel of the VR6 engine.
Vr6 turbo'd! whee!
ms. D
Postby ms. D » Wed Jun 03, 2009 9:14
Congrats and good luck, they are a pain in the arse to fix and very expensive, hence the reason I got rid of my GTI and bought a Mazda!
s0n1cm0nk3y
Postby s0n1cm0nk3y » Wed Jun 03, 2009 9:14
wow, thats pretty much my old car, i just had the 2004.5 in blue. great find man, all the pain in the arse work done already.
Daily Driver/Fun Car/SCCA Car:
1999 Miata = coldside intake assembly.
http://www.cardomain.com/ride/2996016
it giggle in tunnels with it lol
Postby MazdaTom » Wed Jun 03, 2009 9:14
So how long until you trade it for a white one?
lol I so knew that was coming...
Postby bmwzoom » Wed Jun 03, 2009 9:14
hehehe... Congrats Josh! Can't wait to see it in person!
s0n1cm0nk3y
if i remember correctly i think the gli only came in plantinum gray metallic, deep black metallic, laser blue metallic, and what was salsa/tornado red.
actually in retrospect I do remember the gls/glx with the vr6 having a white verison.
Return to “New Member Forum”
