Synapse BOV
Synapse BOV
Postby kingtut » Sat May 09, 2009 9:14
Is the location/set up the same on an MS3 as it is for the MS6?
For one, this thing is pretty large. I know some people have these installed, but a FMIC would probably solve the fitment issues I'm having. It seems (running in recirc), that the SRI is getting in the way, as well as the lines on port A and B, and the hood itself.
When I ordered this from the RPM store, they told me I would have everything I would need for install--as I specifically asked about the MS3 application in recirc. After waiting for the flange to arrive from backorder, I get it and its just a 1" (or so) straight extension. It would almost seem like you'd need it to be an "elbow" that extends downward or something?
Any ideas?
mOOsE
Postby mOOsE » Mon May 11, 2009 9:14
I can't post from experience but the pics I have seen show no real fitment issues. can you post a pic of how it sits when mounted?
Gmoney
Postby Gmoney » Mon May 11, 2009 9:14
Mine rubbed as well(MS6)...... I just rotated it towards a more horizontal position. Mine just barely leans down towards the recirc side. I had to cut my recirc tube to allow this. Now no more rubbing and hassle free operation.
The rubbing will wear a hole in your silicone lines and hinder the operation. Just loosen the set screws and rotate it up from the recirc side of the BOV. I can't remember eactly what the MS3 looks like compared to the MS6 but I remember it being very similar. It will be worth it when yo get it right.
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
Gmoney
getting some pics for you......be up soon.
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Postby kingtut » Mon May 11, 2009 9:14
mOOsE wrote:I can't post from experience but the pics I have seen show no real fitment issues. can you post a pic of how it sits when mounted?
Unfortunately not, sorry.
Gmoney wrote:Mine rubbed as well(MS6)...... I just rotated it towards a more horizontal position. Mine just barely leans down towards the recirc side. I had to cut my recirc tube to allow this. Now no more rubbing and hassle free operation.
Thanks for the reply Gmoney. Interesting- regardless of how much the BOV was tilted, it still seemed to come into contact with the hood.
Gmoney
I believe we use the same cold pipe, just put a BOV on a MS3(I'm Batman's)
I took some pics showing my orientation, now you have a SRI, and the filter might be more of an issue for you.:confused:
to get an idea of the angle of mine......
just the big picture and shows how close everything is.
IMG]http://i582.photobucket.com/albums/ss269/glisano1/IMG_0115.jpg[/IMG]
this shows that the BOV is as high as I can get it with out interfering with the valve cover vent to intake tube.
IMG]http://i582.photobucket.com/albums/ss269/glisano1/IMG_0117.jpg[/IMG]
just trying to show that the top of the BOV is almost the same level as the TMIC shroud.
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney
I guess the pics were to big the other two:
Now I have the upgraded engine mounts in my car, front and back. I have a 2-3 inch scar where the BOV rubbed without me knowing. It started acting weird, so I checked and sure enough there had been a hole worn in the top line. Now I am betting I have about 1/4 inch clearance now with the hood closed.
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney wrote: now you have a SRI, and the filter might be more of an issue for you.:confused:
That was another issue, lol.
Regardless of all the drama that was involved, I would like to give props to Eric / firestoned for offering up his assistance. He's already given me a few pointers, as well as providing info on installation specific to the Synapse. As others have said, its too bad he's no longer a part of this club:(.
Thanks to those that have posted up as well:D
Gmoney
kingtut wrote:Regardless of all the drama that was involved, I would like to give props to Eric / firestoned for offering up his assistance. He's already given me a few pointers, as well as providing info on installation specific to the Synapse.
+1
He has helped me out a few times.......I am in HR and would not mind helping you get it all put together. Now I used his method as well and it works flawlessly. I am a gimp right now, as I decided a good Mother's Day gift would be myself stepping on a framing nail that almost went completely through my foot:eek:
If you don't mind me hopping around, I could lend my assistance....;)
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Postby Number2 » Mon May 11, 2009 9:14
I am interested in buying a BOV in a couple of weeks. Was looking at the HKS, but I'm more interested in the Synapse now. Is the install a headache, or is it easily fixed?
Thanks,
Paul
Number2 wrote:I am interested in buying a BOV in a couple of weeks. Was looking at the HKS, but I'm more interested in the Synapse now. Is the install a headache, or is it easily fixed?
Thanks,
Paul
The fact that I'm having problems doesn't really say much. As I'm pretty up front with the fact that I have zero mechanical expertise, lol. I think the Synapse has one more step than the HKS, but nothing big. Both have issues with (potentially) rubbing on the hood. The Synapse is much larger than the HKS, and most people have upgraded from the stock TMIC, so that alleviates some of the fitment issues from the get go.
...I think the Synapse is a bit cheaper too:cool:. Although these seem to be less heard of than the HKS (pertaining to Mazdas anyway), when doing some researching, they seem to be widely used among other platforms.
bobopud
Postby bobopud » Mon May 11, 2009 9:14
To the OP,
As far as the Synapse goes. I am in Dallas for the week, but I also have the Synapse installed with the boost line tapped by the hot pipe. I can help out with any pointers or tips or install help as well.
mOOsE
Postby mOOsE » Tue May 12, 2009 9:14
I am curious about the synapse too, hopefully it gets all straightened out...def looking at one for my car.
Users browsing this forum: No registered users and 168 guests
