Torque Wrench?
Tire and Wheel Discussion
deepSpeedMS3
Torque Wrench?
Postby deepSpeedMS3 » Thu May 07, 2009 9:14
When i take off my rims and wheels to paint them, do i need to have a torque wrench to put them back on?
B) deepSpeed MS3 B)
Postby AIM WO4 » Thu May 07, 2009 9:14
No. Just need it to torgue them to the correct specs. LOL
Postby MazdaTom » Thu May 07, 2009 9:14
I took wheels on and off for years without a torque wrench. Never had any issues. Now I have one. Is it calibrated correctly? I dunno.
Postby Ranger » Thu May 07, 2009 9:14
You don't "need" to have one, but it's a good idea, especially if you're at the track. They will come in handy for other applications where you do need one, such as any suspension work you might do. In the past I have tightened my lug nuts with a regular old 3/8" ratchet and they came loose. Also for 5-lug vehicles it's a good idea to put the lug nuts back on in a star pattern, i.e. don't tighten one nut and then tighten the one right next to it. Instead, tighten one nut and then do one across from it.
bobopud
Postby bobopud » Thu May 07, 2009 9:14
A torque wrench is always nice to use, but I have found that it is damn near impossible to over torque a lug unless you have a wrench with a handle longer than 2 feet. That said, it is always handy to have at least one or two different sizes of torque wrenches just in case you need them.
Usually the bolts will fail before the lug threading will. I found this out through experience as I did not wait for my car to cool when I was taking my summers off last year. I sheared the lug bolt off and had to have it replaced.
Fly boy
Postby Fly boy » Thu May 07, 2009 9:14
:steph:
What they all said, but a concern that you need to worry about is crossthreading your nut back on. I did it to my Titan and had to sheer the stud. Simple fix, just a pain for ANOTHER fix.
deepSpeedMS3
Thanks for all the advise. NOW, if i were to buy a torque wrench what would be a good price and where to buy one?
B) deepSpeed MS3 B)
I have a $100 Craftsman (Sears) torque wrench.
yep! sears
deepSpeedMS3
ouch.. $100 dollars for a wrench ill use like maybe twice in the next 6 months. Ill have to check with a buddy to see if his shop has one i can borrow. Is there any specific wrench i should buy? size?
B) deepSpeed MS3 B)
Regulator
Postby Regulator » Thu May 07, 2009 9:14
Well, my wheels haven't fallen off yet and I've never used one lol but I def would use one if I had it.:D
Fly boy
deepSpeedMS3 wrote:ouch.. $100 dollars for a wrench ill use like maybe twice in the next 6 months. Ill have to check with a buddy to see if his shop has one i can borrow. Is there any specific wrench i should buy? size?
You can do the Autozone rent-a-tool program if you really want to torque it, but don't want the wrench.
deepSpeedMS3
ne idea how that works?
B) deepSpeed MS3 B)
Gmoney
Postby Gmoney » Thu May 07, 2009 9:14
Just buy one.......it will come in handy numerous times and yep mine is a hand me down Craftsman from my dad........about 15 years old and use it a good amount. I use it every time I remove my wheels.....I recheck them after a few days of driving, you would be surprised how many lugs lose their torque.:)
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
deepSpeedMS3
what size wrench? is there a special size? i saw a couple at sears
B) deepSpeed MS3 B)
Return to “Tires and Wheels”
