clutch removal
clutch removal
does anybody here know a easy way to remove a trany from a p5 so i can do the clutch mine went out i only have 3 and 4 i think that the only gears that it will move in and both of them are the same
You clutch went out yet you still have 3rd and 4th gear? That's not usually how a clutch works. When I've worn out clutches, they usually just slip.
Have you looked at the Factory Service Manual?
I would agree with Tom, are you sure it is the clutch?
I'd search some of the other forums (like 24/7) for "shift fork" or something. I'm not too up on the Protege manual transmissions since I have an auto, but every once in awhile I hear grumblings about shift forks breaking.
When i did the engine swap for my P5 it wasn't hard at all. there is only one engine harness to contend with, the shifing bolts, i think only two vacume lines, and i believe thats all. Once you get the engine out doing the clutch and the flywheel is really easy. How many miles do you have on the engine?
Up Next: Project RX-8!
The reason i ask is because its really easy to swap a clutch with the engine and trany out of the car. That would also be a good time to consider getting a timing belt, ideler (sp sorry), and do a tune up on the car (oil, transmission fluid, coolant, oil filter, spark plugs, wires,) Is the head gasket okay or is it leaking?
And no you can't use a transmission off a mx6 (i thinks its different, ask Tom).
Do you have enought for the other tune up parts and the deep sump? I am told its a pain to do a clutch with everything in the car. Good luck, let me know if you need help.
Users browsing this forum: Bing [Bot] and 115 guests
