FS: 1993 Mazda RX-7 touring montigo $10,990
efini
Postby efini » Mon Mar 16, 2009 9:14
This Montigo Blue 1993 RX-7 touring has 96,000 original miles on the chassis and 4,000 on a newly rebuilt motor.
Motor
The motor was rebuilt around 4,000 miles ago with gentle porting done on the exhaust ports. It will handle high levels of boost and pulls healthy vacuum at 13mm at idle. In it’s current built it is FAST. I recently outran my friends new 335i BMW. No smoke from the motor is produced while driving.
Turbos
The turbos are in excellent condition with minimal horizontal shaft play (and no vertical shaft movement) and will boost a full 16psi if required (not suggested). They appear to have approx. about 20,000 miles on them.
Paint
The vehicle is in good mechanical condition, the paint is in need of an overhaul. The clear-coat is peeling in spots and there is some body damage (shown) under the drivers side door handle. The car is to be sold unpainted to give the owner the choice of paint upon purchase.
Interior
The interior is in good condition given the age of the vehicle. There is no cracking or peeling of the dash material. The dash material is in fair condition and the leather on the seats shows only mild wear.
Touring
The touring model includes Moon Roof, Leather Seats, Fog Lights and Bose CD Stereo.
Mechanical Modifications
Apexi Catback
High Flow Cat
Bonez Down Pipe
Apexi intake
M2 ECU
Short throw shifter
Pioneer Head Stereo
Hard intake charge pipes
Torque Engine Brace
Strut Tower Brace
17” SSR rims
Carbon Fiber Hood (original hood included as well)
Known Issues
The low oil and coolant sensors need to be reconnected
The midpipe-downpipe gasket should be replaced
The manual boost controller (included) was removed to avoid 15psi boost levels which it was unable to control
Fog lights are not operational
Contact
Matt Emmi - 720.352.5297 mattemmi [at] me.com
I can complete the transaction through a local dealership which should allow you to finance the vehicle if necessary.
Photos
http://www.mattemmi.com/alive/RX7.html
Postby speedjunkie » Wed Mar 18, 2009 9:14
Looks good! I wish I had the money, not a bad price.
efini
Postby efini » Fri Mar 20, 2009 9:14
bump.
efini
Postby efini » Tue Mar 24, 2009 9:14
Ttt...
