RPM Street Spings.....
Gmoney
Postby Gmoney » Thu Mar 12, 2009 9:14
Well today I had the morning off and decided to tackle the spring install...:(
I have done this on a couple car before this one and thought it would be a pain in the arse......
The rear springs were very easy and I was able to get them done in about an hour for both......
The fronts were a little more challanging do to the interesting way the shock body attaches to the front fork....never seen it done that way......The most time consuming part is the compressing and decompressing of the springs(always)....that is the pain of the install......I might have been lucky no sticky bolts or nuts or problems....Just a slippery end joint......:D
All in all it was about a 3-3.5 hour ordeal that yielded great results.......got the drop i wanted, I no longer have a MS6 that looks like a rock crawler, but a more sporty feel and smoother ride. I will snap some photos as soon as I can find my camera, still packed some where........I would recommend this to anyone looking for a more subtle drop, not slammed look. The ride is not much different then stock, although you will feel the highway imperfections a little more. It also does as claims equals out the the fender gap between the front and back.......I am a big fan thus far
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
bobopud
Postby bobopud » Fri Mar 13, 2009 9:14
Sounds good. I hope to see it rolling around sometime soon. For how many speeds there are in the ranch I never see any of you guys.
These are the Springs I want to get as well.
Postby movovr » Fri Mar 13, 2009 9:14
Gmoney wrote:Well today I had the morning off and decided to tackle the spring install...:(
Nice Greg! The mod bug HAS in fact reared it's head :) You have a spring compressor or did you rent/borrow from somebody? I only ask b/c its something I've been thinking about doing but don't have the tools.
Rich
Postby Rich » Fri Mar 13, 2009 9:14
Good stuff Greg. You should notice a significant reduction in rear squat under WOT, and better cornering stability as well.
Postby MazdaTom » Fri Mar 13, 2009 9:14
Autozone has spring compressors for rent- put down a deposit and you get the money back if you bring them back.
Postby RX-7 Chris » Fri Mar 13, 2009 9:14
movovr wrote:Nice Greg! The mod bug HAS in fact reared it's head :) You have a spring compressor or did you rent/borrow from somebody? I only ask b/c its something I've been thinking about doing but don't have the tools.
I think all the talk about getting the mod bug is funny. I was born with mine. I haven't left anything alone ever.
I can't wait to see some pics.
Gmoney
Postby Gmoney » Fri Mar 13, 2009 9:14
bobopud wrote:Sounds good. I hope to see it rolling around sometime soon. For how many speeds there are in the ranch I never see any of you guys.
I know, I have seen you once i think, but that was a while ago.......
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney
I got mine from checker auto parts it was like $60 and I get back $55 of it when I return it.......they worked well. As for tools it was just a breaker bar, torque wrench, 17mm,14mm,12mm sockets, a couple extensions, adjustable wrench, 14mm open wrench and a couple sizes of ratchets, a couple bloody knuckles:(.
Can't speak for the MS3 but the job was a afternooner for one person, probably go faster with two.....Let me know I could lend a hand
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Postby ~Barn~ » Fri Mar 13, 2009 9:14
Gmoney wrote:<snip...> I no longer have a MS6 that looks like a rock crawler
Ha! Now that's comedy, right there!
I'm excited to see pictures as well. On more than a couple of ocassions, I've wanted to order these, but the install has been the worry.
And on that note, what is your per-hour labor charge? :D
Congrats on the new look!
Postby tsx_guy » Fri Mar 13, 2009 9:14
i am thinking spring install meet peoples?
Greg I would like to take a ride so see how the springs feel when you get a chance.
303native
Postby 303native » Fri Mar 13, 2009 9:14
Are the RPM Streets an even drop all around, or are they a little lower in the front?
Regulator
Postby Regulator » Fri Mar 13, 2009 9:14
Where were you when I was paying to have mine installed! I would have rather done it on my own and gained some knowledge, but I didn't have any of the tools :(
Anyways... Still wanna see the pics of the ride
Gmoney
Well here are some pics I took with my iphone..........
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney
6i_guy wrote:i am thinking spring install meet peoples?
Give me a ring......
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Gmoney
~Barn~ wrote:Ha! Now that's comedy, right there!
I am easy just a pat on the back and a 6pk......:cool:
oh ya, that per hour......:D
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
Users browsing this forum: Bing [Bot], Google [Bot] and 140 guests
