auto vs manual 4x4
auto vs manual 4x4
my bro just got a jeep cherokee and keeps arguing that a auto is better than manual for offroading and honestly i cant see where a auto would be better at all.
it is better in most respects.
Have you ever done rock crawling with a manual?
it is hard to keep from riding the clutch and stalling.
Where a manual is better is when you are going down hill, you can just put it in a low gear and coast. With an automatic, you have to ride the brakes.
Can you use gear reduction boxes with autos?
My parents had an '88 Cherokee Pioneer back in the day. With that thing in 4L and the transmission in L, you didn't need brakes while going down a hill- you actually needed a touch of gas to keep from slowing down too much.
That works on some automatics. It depends on the gearing in the trans and transfer case. It needs to be real low to get that to work right.
I was into 4-wheeling long before I owned a mazda.
i did the 4 wheeling thing too before my mazda and i hated havin an auto. you would pull up onto a rock and have to wait for the trans to build up pressure. then it would kick down when i wanted it to be in a different gear. i would watch my buddy with the same truck idle up stuff in 3rd while i was spinning my tires in 1st or 2nd
What kind of truck and trans?
just so i can correct myself... he wasnt idling up rocks n 3rd we were going up different obstacles. my experience with rocks is that with the auto you have to build up pressure in the trans / tq converter and let off quick once so you dont come down too hard.
there is your answer, Nissan
Not the best trans.
A lot of it has to do with what converter you have in there. With a motor that has a lot of low end, you can have a real low stall converter and that problem goes away.
Not the best trans.
- goldrocket
I've owned a fourwheeler for the last 15 years in some form or another, and they have all been autos. Never had a problem crawling or climbing big hills. In fact I could climb some hills that my friends with manuals couldn't. they'd lose traction and I'd just keep the throttle steady and drive right over the stuff they were getting stuck on.
Al says
