SO the question is.. What size of tire could I get that would fit both rims? I want to do this so that I could swap them back onto my stock wheels when winter comes back around...
Stock: 215/45/18 18x7"
My rx8s: 235/40/18 18x8"
cprtrainer wrote:Yes, you can do a 225/40/18 on both. my Ms6 came with those on the stockers, my rx-8 rims that I use for summer on my 5 also wear the same size now. if you would like to see what they look like (just a little stretched), hit me up next time you are in Brighton and I can show you.
the only issue I had with the size on my 6 was the speedo read a tad fast- about 2mph quicker.
That way you will only need to buy one set and be done with it. 225 is the max width for safe use on a 7" rim.
bmwzoom wrote:I have stretched my 18x7 tires onto my CX-7 rims that I have now and I was told they were an inch wider. So, yes, it is possible and I am using them as I speak on 18x8 rims
Users browsing this forum: No registered users and 33 guests
