Okay, I am going to go against the norm here, mostly out of necessity. I want to get some stiffer springs to help with the stock suspension on the speed6, however, I don't want to lower my car anymore than it already is. Wheel gap does not bother me, and I al ready scrape the plastic brush guard comming out of my garage in the mornings, so going any lower won't be any nicer on my car.
Are there any springs out there that offer all of the benefits without lowering the car anymore? Everything I have seen shows at least some drop.
Also, please educate me on the basics of suspension mods. I have never done any and I think that will be my next set of upgrades after I decide on a tuner.
Thanks.
MS6 Springs
MS6 Springs
You might be able to find some springs that only lower 1/2" to 3/4" but I don't think anyone makes stiffer springs that don't lower at all.
If you want the car to corner better maybe the way to go for you is larger sway bars and strut bars. and keep your stock springs.
- Rich
The RPM Sports are probably your best bet. Only 1/2" drop in front and rear, with a good increase in spring rate @ 18% front, 22% rear. Also they're fairly cheap, for $230.
http://www.therpmstore.com/product_info.php?cPath=91&products_id=442
+1
I think your best bet would be the RPM Sport springs, claims that there is only a .5 inch drop Front and Back. They are 18% stiffer up front, and 22% stiffer in Back. I know Rich has there Street Springs and seems to be happy with them. Good Luck.....Let us know if you find any other options....
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
So I was looking at the RPM store last night and see that they have their "street" set and their "sport" set of springs.
My MS6 being otherwise stock, will I notice any rubbing/clearance issues by going with the street springs? According to the ad, they'll drop the car 1.1 and .75 inches, front/rear respectively.
Also, what kind of labor hours should this take a shop, to install them?
Does anything else need to be purchased/replaced when swapping springs, or is it a simple 1-out-1-in procedure?
Thanks!
Thanks!
Sometimes, not always, when upgrading to a stiffer (faster) spring you'll want to upgrade your struts/shocks at the same time. The reasoning behind that is with the stiffer spring rates, the internal valving inside the strut/shock will quickly wear out due to the increased suspension movement speed.
Patrick- did you ever decide to get new springs? If so, I'll be there with tools in hand. Or we can do it in my garage.
That goes for you too Barn.
I'm still looking into it, but at this point I would rather get a FMIC and tuning. That will probably set me back close to $2000 unless I get a custom FMIC. Either way I have a hard time spending too much on something I want in this economy.
I think I will be in save mode until the economy starts to turn it around. I'm not worried about my job, but I don't have the reserves that I should at this point. Unfortunately the fun stuff should wait until I get the needs taken care of. I hate having to be a responsible adult.
Users browsing this forum: No registered users and 30 guests
