RX7 Coolant Seal Failure
hey111you
Postby hey111you » Thu Dec 04, 2008 9:14
Anyone out there ever do, or have done by someone else, a diagnosis of a Coolant Seal failure on a 13B engine (or other rotary for that matter)?
Postby Ranger » Thu Dec 04, 2008 9:14
Well, 13Bs have multiple coolant seals so it's hard to say without a teardown...but a diagnosis should be pretty straightforward. Check for signs of coolant leaking out of the engine block, white smoke on cold start (or even worse, while running), a sweet smell to the exhaust, etc. Check your coolant level frequently...if it is repeatedly getting low then you know you have a problem. Also, pull the radiator cap and start the car, let it warm up a bit...look into the radiator...if you see what looks like champagne bubbles in the coolant that's almost a sure sign you've got a bad seal.
What car is this in? Is it stock?
Low Impedance
Postby Low Impedance » Thu Dec 04, 2008 9:14
you may also find the coolant pressurizing
WWW.RCCDIGIZINE.COM
Postby RX-7 Chris » Thu Dec 04, 2008 9:14
Ranger has it right on. I think Limp means excessive pressure.
Postby iani1.1 » Sat Dec 06, 2008 9:14
rebuild time or you can try this http://www.rotaryresurrection.com/3rdgen/tech_coolant_seal_fix.html its only a temporary fix but itll hold of a awhile, did it on my old 7 til i saved up enough money for a TII swap
Users browsing this forum: Baidu [Spider] and 96 guests
