New to the Mazda world
Just4fun
Postby Just4fun » Tue Nov 04, 2008 9:14
Hello,
I just picked up my first Mazda. A 2006 Speed6. I heard about this club from the dealer I bought the car from.
I have always been a Mustang guy but wanted a fun car for my driver.
So far the only complaint I have is the flat spot in the upper revs. How do I get rid of that?
Postby Huzer21 » Tue Nov 04, 2008 9:14
Welcome aboard! I thought about the Speed3/Speed6 before I ended up in my RX8. There are plenty of knowledgeable Speed6 guys here for you.
Just4fun
Thanks.
I also need to get rid of the sloppy shifter it comes with. Any help on that would be appreciated as well.
Postby Ranger » Tue Nov 04, 2008 9:14
Welcome! Not an MS6 owner myself, but I would say that unfortunately there is no easy way to get rid of a lack of torque at higher RPMs. You would need to do some serious tuning. The shifter however is an easier fix. There are several short shifter kits out there that will most likely improve the feel, but there's nothing out there that's going to make it feel like a Mustang. :)
Postby Colombia28 » Tue Nov 04, 2008 9:14
Welcome to the club and welcome to the "dead after 5500" club ;)
In stock form the K04 turbo cant push enough air up top, a good tune will help out up top.
And then there is the shifter... lol. Shifter bushings are a great start to help firm up the feel, but a short shift would be best. A few people on here have short shifts on their MS6 and love'em. Hopefully they will chime in.
bobopud
Postby bobopud » Tue Nov 04, 2008 9:14
The cheapest way to get rid of the flat spot is to shift before it. This engine was not designed to be a redliner like the honda civics and RX-8s of the world. Other then that you probably need a bigger turbo in order to hold boost higher in the rpm range, but that requires a lot of supporting mods.
Welcome by the way.
Postby RX-7 Chris » Tue Nov 04, 2008 9:14
Welcome to the club
Postby bmwzoom » Tue Nov 04, 2008 9:14
Welcome to the club... glad you joined us! :)
thegreenthief
Postby thegreenthief » Wed Nov 05, 2008 9:14
I had similar feelings about the Speed6 when I took it on a test drive about a year ago.
Then I settled on my RX-8 and I haven't been happier. =]
Welcome!
firestoned
Postby firestoned » Wed Nov 05, 2008 9:14
TWMperformance.com has the shifter you need, it comes in 2 stages, stage 1 is same heighth, shorter throw, and stage 2 is 30% shorter heighth w/ shorter throw. Definitely get the shifter base bushings also, they help alot..
Getting rid of the "flat spot" in this car can turn your mod list into a novel for sure, Id recommend getting an engine management system first, then build from there.. I for one noticed a big improvement with the DN Performance turbo manifold, brought the car to life at higher rpm's. Also, consider freeing up SOME of the exhaust restriction. I say SOME because alot of speed owners have found if you completely remove all the backpressure, you may experience smoky turbo syndrome. A catted downpipe, such as the one HERE, is a great option to consider. Other helpers are more obvious, like the intake, and bpv. Like I said, the list can keep going and going and going. Let me know if you need any help, or have any questions
Oh, and welcome to the club..
Just4fun
Postby Just4fun » Wed Nov 05, 2008 9:14
Thanks all for the info. I will definietly look at ditching the notchy shifter for something more precise.
Postby tbot » Wed Nov 05, 2008 9:14
welcome to the club...and i couldn't offer any help to ur issues unfortunately since i have a mazda 3...with an auto none the less...
Postby iani1.1 » Wed Nov 05, 2008 9:14
welcome. didn't know the 6's get that dead spot at 5500rpm thought it would be at like 6200rpm or something higher. but +1 on the ems
Postby TheNewBlack » Wed Nov 05, 2008 9:14
Welcome!
Just4fun
Postby Just4fun » Thu Nov 06, 2008 9:14
I was thinking the flat spot came in around 5200 or so. It seems to just get past it and then runs out or revs.
All in good time I guess...
Return to “New Member Forum”
