The building block
Eric I'd say Ceramic coat it as well. Or you can be like me and backfire all day long :P
The EGT would not be lower. Having a ceramic coated mani would keep the exhaust heat out of the underside of the hood and move it out the exhaust. The ceramic coat does not make the heat go away, it only keeps it from leaving the pipe.
Whatever josh
firestoned
I would think they should be, but it shouldn't make a huge difference. It might be something that would make an interesting before and after.
firestoned
firestoned wrote:header wrap is NOT RECOMMENDED at all, especially on tubular manifolds, because the header wrap will hold moisture between the barriers, and can crack the manifold
blah blah blah. It all depends on the type of steel used. Mild steel - do not wrap. Stainless steel - OK to wrap. I wrapped the factory stainless header (yes, I said factory) on my Saturn. Not an issue. Before doing so, I was also aware of this phenomenon and after talking with a metalurgist, he asured me that as long as my header wasn't mild steel, I would be fine.
Wrapping ceramic coated mild steel....... I think it would be OK since the ceramic coating should isolate the steel from any moisture.
Wrapping ceramic coated stainless steel = probably overkill.
A heat sheild is a good idea. Especially if you're still using the top mount heat soaker- I mean interwarmer, I mean intercooler.
- Colombia28
Users browsing this forum: No registered users and 257 guests
sorry to stray off topic but this had me lol'ing hard! Nice one Tom!
