garage
firestoned
garage
Postby firestoned » Fri Sep 26, 2008 9:14
Why is the garage so difficult to add modifications? It seems that there is no list for parts and very limited suppliers.. cant we just fill those sections in on our own??
Postby RX-7 Chris » Fri Sep 26, 2008 9:14
the Mods need to add suppliers etc. If you have a list for me I can add those.
Postby Huzer21 » Fri Sep 26, 2008 9:14
yes, those sections can be filled out on your own. For the required fields (which are hard coded and I can't make them optional) just click on the "not listed" link and add. If you don't want to add a manufacturer, you can choose "manufacturer unknown". I've been told in the next software release, the required fields will be made editable, but I don't know when that will happen.
firestoned
i try to add, and it says an administrator will approve the addition... I added parts over a week ago, and they still do not show up
Lemme check. It shouldn't be set to administrator approve...
Postby bmwzoom » Fri Sep 26, 2008 9:14
I second this.... same thing happens to me.
I approved added mods/manufacturers. Not sure if there's a setting I can change, but I'll look.
EDIT:Found it. Fixed. Sorry, I didn't write the garage, I only bought/installed it. I'm tryin' to learn it, though.
Operator
Postby Operator » Wed Dec 15, 2010 9:14
How long does it take to have a car added to the garage? I filled out everything and it's still not visible.
JL 1000/1 - JL 450/4
[/font]
Current:
Postby Huzer » Thu Dec 16, 2010 9:14
Should be immediate. I don't see anything "pending" anywhere, so I'm not sure what might have happened.
Return to “Colorado Automotive Enthusiasts News and Info”
