new memeber just joined today
Postby MazdaTom » Tue Sep 09, 2008 9:14
<div class='quotetop'>QUOTE (Buffalo @ Sep 9 2008, 02:50 PM) [url=index.php?act=findpost&pid=62597]<{POST_SNAPBACK}>[/url]</div>
What are you thinking of? I have an extra intake mani sitting at home right now. Something you might be interested in?[/b]
I've already pulled the VTCS butterflies out of mine and lightly ported it, so I'm relatively good there. The 626 manifold "might" work well on a NA setup, but everyone seems to poo-poo the idea without trying it.
I was thinking more along the lines of the JDM intake camshaft from Corksport and an exhaust mid-pipe from Protege Garage. And then at some point get a piggy back controller. But the only problem there is that so far only the high end units like the Microtech (>$1000) gives timing advance control. Other units allow timing retarding, but for NA, you need to advance the timing. The AEM piggyback might in the future as that system is constantly evolving and getting updates and new features.
Beyond that, to add more power to my car, I have to open up the engine and start swapping pistons-> something I'm not looking to get into with this car.
Postby RX-7 Chris » Tue Sep 09, 2008 9:14
Stay on topic please
Buffalo
Postby Buffalo » Tue Sep 09, 2008 9:14
I hear the Miata pistons are they way to go, if you do decided to go there. What about taking your head into a machine shop and getting that ported as well?....Correction, wouldn't help if you can't advance the timing.
Up Next: Project RX-8!
ProjectMSP
Postby ProjectMSP » Tue Sep 09, 2008 9:14
so anybody going to bandimere tomorrow for test and tune? i will be there either by 5:30 ish or 7:30ish hopefully depending on if they let me go a little early, i just want 1 run :(
MY CAR
OLD RIDE
ProjectMSP
Postby ProjectMSP » Thu Sep 11, 2008 9:14
well i ran at bandimere got 2 runs in
1st run and i dont understand how i ran faster. was
16.714 at 85, and i missed second
2nd run
17.104 at 84.35 with my girl in the car
idk what the stock times are but i need to track down this insane boost lag im getting.
EDIT: was reading stock MSP times should be mid to high 15's, i dont get it , i guess not at sea level makes a difference
MY CAR
OLD RIDE
Postby RX-7 Chris » Thu Sep 11, 2008 9:14
You will loose a good part of a second up here. You will not loose as much as a N/A car though. I would think you should be at about 16.5 up here.
supernatural006
Postby supernatural006 » Sat Sep 13, 2008 9:14
Welcome!!
Return to “New Member Forum”
