mp3/es and up drivers, show me your head units!
s0n1cm0nk3y
Postby s0n1cm0nk3y » Sat Sep 06, 2008 9:14
curious, I happened upon the little glove compartment with door contraption that was in an 00 protege es. I am curious if there is anything that comes with the mp3s or the es and up cars that holds this all in place. So far I have it all instead, but the sleeve is really the only thing keeping it all in place, and I am curious if there are other, more sturdy means.
Daily Driver/Fun Car/SCCA Car:
1999 Miata = coldside intake assembly.
http://www.cardomain.com/ride/2996016
Postby MazdaTom » Sun Sep 07, 2008 9:14
I think there's a support bar that goes in there when used with the pocket. I don't have the pocket or the support bar.
zoomin MP3
Postby zoomin MP3 » Wed Nov 26, 2008 9:14
s0n1cm0nk3y wrote:curious, I happened upon the little glove compartment with door contraption that was in an 00 protege es. I am curious if there is anything that comes with the mp3s or the es and up cars that holds this all in place. So far I have it all instead, but the sleeve is really the only thing keeping it all in place, and I am curious if there are other, more sturdy means.
Did you still need help with this? There should be a support bracket in the car at the back of the head unit. There sould also be a bolt with a rubber nipple (for lack of a better term) on it that fits inside a hole in the bracket. That gives the head unit and storage tray support in the rear to keep things stable.
EVO CF hood and decklid, [color=#008000][color=blue]BC 2 sideskirts and rear bumper, DG front lip, [/color]iSport CF ADP, Daveb brushed rings, AWR front/rear mm, SLS pass mount, Medieval pullies, K&N CAI w/ ram air tube, TWM ss, mazda racing 4-2-1 header, Magnaflow custom exhaust, AXR "clunk fix", 6K HID, MP3 seatbelt pads, dual pod guage bezel, innovate WB guage, smoked fender lights, smoked/painted tails, drilled/slotted rotors, MSP interior[/color]
