clutch petal bracket
icon
Postby icon » Sat Aug 30, 2008 9:14
so i go to start my car today, push in the clutch petal and hear a loud pop. the clutch petal feels really spongie and i have to press it all the way in to get the car into gear and to keep if from dying. i finally make it home and i see that the clutch petal bracket has a crack in it. anybody know how much this will cost to get replaced ot if mazda will cover it?
2005 RX-8
Postby GR-8 » Sat Aug 30, 2008 9:14
<div class='quotetop'>QUOTE (icon @ Aug 30 2008, 10:42 PM) [url=index.php?act=findpost&pid=61856]<{POST_SNAPBACK}>[/url]</div>
so i go to start my car today, puch in the clutch petal and hear a loud pop. the clutch feels really spongie and i have to press it all the way in to get the car into gear and to keep if from dying. i finally make it home and i see that the clutch petal bracket has a crack in it. anybody know how much this will cost to get replaced ot if mazda will cover it?[/b]
You are still under warranty right? Take it in and they will fix it. If that dealer won't go to another. It should be covered don't take any other offer they tell you. It's a known problem. Just unflash the AP before you go.
icon
<div class='quotetop'>QUOTE (Greek8 @ Aug 30 2008, 10:44 PM) [url=index.php?act=findpost&pid=61857]<{POST_SNAPBACK}>[/url]</div>
You are still under warranty right? Take it in and they will fix it. If that dealer won't go to another. It should be covered don't take any other offer they tell you. It's a known problem. Just unflash the AP before you go.[/b]
i dont know if my car is still under warranty
2005 RX-8
It's should still be. Is it and 05? If it's an 04 if it was purchased before Sept this year you are still under the powertrain warranty unless you are over 50k miles. But then again you cuold go in there and tell them it's a know issue and should be changed for free. It's a part of the car that shouldn't break anywho. I mean a 1970 whatever that's rusted and beat up will still have a working clutch pedal braket.
icon
Postby icon » Wed Sep 03, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Aug 30 2008, 11:04 PM) [url=index.php?act=findpost&pid=61862]<{POST_SNAPBACK}>[/url]</div>
It's should still be. Is it and 05? If it's an 04 if it was purchased before Sept this year you are still under the powertrain warranty unless you are over 50k miles. But then again you cuold go in there and tell them it's a know issue and should be changed for free. It's a part of the car that shouldn't break anywho. I mean a 1970 whatever that's rusted and beat up will still have a working clutch pedal braket.[/b]
so i got my car towed to go mazda off 104th and federal yesterday. they are going to fix the clutch petal bracket under warranty. they are also doing some recall for a "lack of power"??, any ideas on what they are going to do?
2005 RX-8
Postby GR-8 » Wed Sep 03, 2008 9:14
Ru a bunch of tests on the car. If they fail at any point they may run a Compression test to ensure the car has the right compression. If that fails you will be due for a new motor under warranty.
May be also a clogged cat. They will check that also.
icon
<div class='quotetop'>QUOTE (Greek8 @ Sep 3 2008, 11:45 PM) [url=index.php?act=findpost&pid=62152]<{POST_SNAPBACK}>[/url]</div>
May be also a clogged cat. They will check that also.[/b]
new engine doesnt sound too bad.
2005 RX-8
Postby Huzer21 » Thu Sep 04, 2008 9:14
Lack of power recall is MSP16, an ECU flash. I'd be surprised if they did anything other than that.
icon
Postby icon » Thu Sep 04, 2008 9:14
<div class='quotetop'>QUOTE (Huzer21 @ Sep 4 2008, 08:06 AM) [url=index.php?act=findpost&pid=62163]<{POST_SNAPBACK}>[/url]</div>
Lack of power recall is MSP16, an ECU flash. I'd be surprised if they did anything other than that.[/b]
how much of a gain does it give?
2005 RX-8
Postby GR-8 » Thu Sep 04, 2008 9:14
I think that they still check all that stuff. Especially considering that its a 05. There are rumourse that it will take away some power but there are also those that have experianced a 10HP increase. Just rumourse and speculation.
icon
Postby icon » Fri Sep 05, 2008 9:14
<div class='quotetop'>QUOTE (Greek8 @ Sep 4 2008, 10:53 PM) [url=index.php?act=findpost&pid=62259]<{POST_SNAPBACK}>[/url]</div>
I think that they still check all that stuff. Especially considering that its a 05. There are rumourse that it will take away some power but there are also those that have experianced a 10HP increase. Just rumourse and speculation.[/b]
take away? good thing i have the ap, but mazdamaniac still hasnt sent me maps after 3 weeks
2005 RX-8
icon
Postby icon » Tue Sep 09, 2008 9:14
i finally got my car back today. they replaced the slave cylinder, the clutch petal, the clutch petal bracket and the clutch switch.
2005 RX-8
Postby Huzer21 » Tue Sep 09, 2008 9:14
Good deal! How's the shifting feel with all of that replaced? Word of advice, the bracket will fail again. Not tomorrow necessarily, but 40k-50k miles down the road. I installed the Mazsport Clutch Pedal bracket kit for peace of mind. It just adds some stiffer reinforcement pieces.
Postby RX-7 Chris » Tue Sep 09, 2008 9:14
glad it was fixed
icon
<div class='quotetop'>QUOTE (Huzer21 @ Sep 9 2008, 02:14 PM) [url=index.php?act=findpost&pid=62589]<{POST_SNAPBACK}>[/url]</div>
Good deal! How's the shifting feel with all of that replaced? Word of advice, the bracket will fail again. Not tomorrow necessarily, but 40k-50k miles down the road. I installed the Mazsport Clutch Pedal bracket kit for peace of mind. It just adds some stiffer reinforcement pieces.[/b]
shifting feels great. how much did you pick up the bracket for?
2005 RX-8
Users browsing this forum: No registered users and 103 guests
