My car is smoking and here's a video.
Postby SpeedRacer » Sat Apr 26, 2008 9:14
Oh something funny I hit fuel cut last night in 4th gear lol...
arctic_blue83
Postby arctic_blue83 » Sat Apr 26, 2008 9:14
<div class='quotetop'>QUOTE (SpeedRacer @ Apr 26 2008, 10:53 AM) [url=index.php?act=findpost&pid=43023]<{POST_SNAPBACK}>[/url]</div>
Oh something funny I hit fuel cut last night in 4th gear lol...[/b]
An Accessport should be able to clear that up for you... but if you get impatient, you can always buy one of these:
http://www.turboxs.com/item.php?ID=139
It got rid of my fuel cut on my Speed6.
BTW, how does the car feel with the DP on? I'm assuming it should pull a good bit harder?
It pulls alot harder i love it! Just sad i haveta go back to stock now..
Postby AIM WO4 » Sun Apr 27, 2008 9:14
I'm with Arctic...
Small puffs of grey/white smoke often come from the tailpipe when stopped. This usually means that the clearance between the impeller shaft and bearings has become excessive allowing oil to leak past the seals. Another indication... large amounts of oil show up in the intake manifold.
I seem to remember this being more common in the Saabs with Garretts, and less common with the Mitsu.
"IHI = Guessing game" LOL
jeffms6
Postby jeffms6 » Sun Apr 27, 2008 9:14
<div class='quotetop'>QUOTE (firestoned @ Apr 25 2008, 06:55 PM) [url=index.php?act=findpost&pid=42933]<{POST_SNAPBACK}>[/url]</div>
turboxs = JUNK[/b]
Aren't you glad you got the catted CPE dp now?
Postby SpeedRacer » Sun Apr 27, 2008 9:14
yada yada yada its a pipe... :P
arctic_blue83
Postby arctic_blue83 » Mon Apr 28, 2008 9:14
<div class='quotetop'>QUOTE (SpeedRacer @ Apr 27 2008, 04:17 PM) [url=index.php?act=findpost&pid=43138]<{POST_SNAPBACK}>[/url]</div>
yada yada yada its a pipe... :P[/b]
+1
It's just a pipe. One pipe will not make the turbo seals mysteriously better, there's no amount of engineering that will make a DP somehow bypass a problem like this :lol:
The only reason why a lot of the CP-E catted DP guys don't have the same problem, is because they still have a cat in their exhaust... which filters out the "smoke" before it can get back to the muffler tip. The "problem" likely exists on their cars as well, they just can't see it, due to the cat "absorbing" the smoke.
Postby RX-7 Chris » Mon Apr 28, 2008 9:14
I saw the car yesterday and it is burning a good amount of oil. it is also spitting a little bit of carbon out the pipe when the car is cold. The carbon only comes out when the exhaust is spitting out the condesation in the exhaust system. The car is smoking more than my car and mine has oil injection.
Josh you taking it in today?
firestoned
Postby firestoned » Mon Apr 28, 2008 9:14
I agree with arctic, it is only a pipe..... i just made the junk comment because Josh seems to have problems with them, thats all...
and even though it is only a pipe, YES I am glad I got the catted CP-E... only becuase the smoke isnt visible...and no CEL... although the other day I threw a P0420, Jordan at CP-E says the cat may be failing, which would result in a HUGE headache, have to remove it, send it in to be rewelded, and then reinstalled.. blah..
goldrocket
Postby goldrocket » Mon Apr 28, 2008 9:14
<div class='quotetop'>QUOTE (SpeedRacer @ Apr 25 2008, 05:38 PM) [url=index.php?act=findpost&pid=42922]<{POST_SNAPBACK}>[/url]</div>
Just got the downpipe put on and now this...
fucker!
http://www.youtube.com/watch?v=yj_XwWte0KU[/b]
Josh, I didn't read all the other posts cause it will take too long. Save yourslef the stress of diagnosing something over the internet and put it on a an exhaust analyzer. 4 or 5 gas won't really matter, just go find out what is coming out, that will tell you if there's a problem.
Al says
S4poor
Postby S4poor » Mon Apr 28, 2008 9:14
Josh, get a 200 cell cat in her. No loss of power, but the smoke should dissipate enough with a 200 cell catching the blow by still.
Careful on getting a hybrid snail. I've seen many go bad, quickly. There are very few places that I would purchase a hybrid from. Buehn Engineering is pretty much the only one to go with IMHO.
Users browsing this forum: Baidu [Spider] and 52 guests
