New RX-8 Technical Service Bulletins (TSB)
Postby Huzer21 » Mon Mar 17, 2008 9:14
First is basically the deflood procedure if you the car won't start after you havent' sufficiently warmed/short drive.
Engine Cranks, No Start
Lack of power when it's warm out...
Engine Lack of Power
Mazda Special Program (MSP16) - Engine Lack of Power -PCM Reflash
MSP16 PCM Reflash
OpacRX
Postby OpacRX » Mon Mar 17, 2008 9:14
cool yeah i will have to go in when its really hot out i lose allot of power and it makes a weird sound it hasnt been a prob because of winter but with summer comming i am going to have to get this fixed
rx8ghost
Postby rx8ghost » Mon Mar 17, 2008 9:14
I haven't had any of those problems and being from Texas I'd know if there was something wrong in high temps but thanks much for the update!
Mods:
Postby GR-8 » Mon Mar 17, 2008 9:14
Me gotta go. I been telling the dealers forever that during hot weather I get rough idle. They look at me like I'm crazy. Oh well.
Buffalo
Postby Buffalo » Mon Mar 17, 2008 9:14
My lack of power is due to Tim stealing my Pettit SC. Once any of you see him with it, take it from him and send it to me.
Up Next: Project RX-8!
rx8ghost
Will do. I wish someone would get the SC. I wanna compare in real life not on paper!!
Mods:
Postby Huzer21 » Wed Mar 19, 2008 9:14
<div class='quotetop'>QUOTE (Buffalo @ Mar 17 2008, 08:45 PM) [url=index.php?act=findpost&pid=33142]<{POST_SNAPBACK}>[/url]</div>
My lack of power is due to Tim stealing my Pettit SC. Once any of you see him with it, take it from him and send it to me.[/b]
Nobody gets my S/C, nobody! Well, unless they buy it before me. Still having a hard time swallowing the nearly 7k price tag, when all is said and done. If/when I go FI, this will still be the route I take.
And my power loss at the moment is substantial, as I don't have my car. They offered a rental after I dropped off the car...if it isn't done this afternoon, I'll go down tonight and pick something up.
Buffalo
Postby Buffalo » Wed Mar 19, 2008 9:14
If you do and they try to put you in a ford tell them again that you turned in an RX8 and they will upgrade you to a Merc Millan or a SUV.
They tried to put me in a focus or something like that and after mentining it, they upgraded me. Hope all is well.
Postby Huzer21 » Thu Mar 20, 2008 9:14
If anyone read the TSBs, this is the one that scares me the most:
Some customers may experience a lack of engine power and an low engine idle speed during high ambient
temperatures. This may be caused by the following conditions:
• Poor sealing of rotor chambers due to an accumulation of carbon on the rotor housing trocoid surface. This is
caused by a lack of metering oil lubrication during engine start or insufficient ignition timing under high ambient
temperature condition. A revised PCM calibration is available which increases metering oil lubrication
amount during engine start. Ignition timing under high ambient temperature is recalibrated as well.
• Poor sealing of rotor chambers due to worn apex seals. This may be caused by lack of metering oil lubrication
during high ambient air temperature conditions. A revised PCM calibration is available which increases
metering oil lubrication during high ambient air temperature conditions.
Postby Huzer21 » Fri Mar 28, 2008 9:14
Has anyone else taken their car in for the MSP 16 reflash? Gateway did mine when I took it there for the tranny. I can't base it off anything, since I had the Cobb test flash on there before, but not sure if there's any "seat of the pants" difference to the flash or not. I did notice it lost a little bit of pep from the flash I was running, so I've since put it back to the Cobb stage 1 production map.
Postby GR-8 » Fri Mar 28, 2008 9:14
My car went in this morning for my clutch pedal. Bracket broke. I suggest that all of you experience random grinding and stuff get on your floor and have a look see to make sure the spot welds haven't broken loose on the clutch braket. I'll call them and ask them about the flash.
UPDATE: I just called and it causes a lack of power and hurts performance. So I think I may not get it done. If I do I doubt I'd tell a difference seeing as I havn't driven the car for 3 weeks now cause of the cluth pedal snapping. Good thing it wasn't on the highway when it went.
