MAZDA 3i CAMBER
jerstillman
Postby jerstillman » Thu Mar 06, 2008 9:14
So in california i have a tire/suspension shop that im extremely friendly with and i was talking to the suspension guy who ever time i would bring my car in he wanted to lower it. But we got to talking about why my back tires were wearing so weird only on the inside of the tire. when we stepped back from the car and look at the back wheels we noticed that the camber on the back tires were at least 2 degrees out of wack. i was just wondering if anyone else has this problem with their car. he told me he could fix it with adjustable camber arms but those are 300 dollars and i dont really have that kinda cash floating around.
Postby tsx_guy » Thu Mar 06, 2008 9:14
a 4 wheel alignment wouldn't correct this? just wondering?
jerstillman
<div class='quotetop'>QUOTE (6i_guy @ Mar 6 2008, 12:04 PM) [url=index.php?act=findpost&pid=30405]<{POST_SNAPBACK}>[/url]</div>
a 4 wheel alignment wouldn't correct this? just wondering?[/b]
no because the camber rods in the rear are not adjustable
Postby Colombia28 » Thu Mar 06, 2008 9:14
When i dropped my old 3 on the Pro-Kit i had negative rear camber, but never corrected it because negative camber is not necessarily bad. Negative camber only accelerates the wear on the tires, but at the same time it provides more rear grip. What are you dropped on? And yeah the rear camber links on the 3's are non adjustable, they are made for the stock ride height ect.
Postby GR-8 » Thu Mar 06, 2008 9:14
I have inside wear on my rears. Don't know why mazda marked them in the green when half the tire is bald?
MS3_Mafia
Postby MS3_Mafia » Thu Mar 06, 2008 9:14
Like Andrew stated, negative camber is not necessarily a bad thing.
I'm gonna be getting these tires in the next month or so... a GREAT Tuner tire especially for vehicles lowered and with some camber. I've had these before on 2 previous lowered vehicle. Grip is killer!
NITTO NEO GEN
http://www.discounttiredirect.com/direct/f...e&tc=NITHZ6
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
<div class='quotetop'>QUOTE (Jerstillman @ Mar 6 2008, 12:17 PM) [url=index.php?act=findpost&pid=30408]<{POST_SNAPBACK}>[/url]</div>
no because the camber rods in the rear are not adjustable[/b]
I guess I was confused, I didn't realize your car was dropped..
Postby SpeedRacer » Thu Mar 06, 2008 9:14
stop hitting shit and you wont have negative camber :P
Postby MazdaTom » Thu Mar 06, 2008 9:14
The best part about tires wearing out is replacing them with new tires. You should welcome your increased negative camber. If you'd like, you can help even out the wear on the outside shoulder by taking corners really fast.
<div class='quotetop'>QUOTE (SpeedRacer @ Mar 6 2008, 03:38 PM) [url=index.php?act=findpost&pid=30455]<{POST_SNAPBACK}>[/url]</div>
stop hitting shit and you wont have negative camber :P[/b]
sir...i don't see how that helps him at all.... f'n post whores...
jerstillman
hahah yeah really. but no my car isnt dropped. and if it was dropped the camber would be even worse. its jsut weird that the factory comes with negative camber i know its not necessarily bad but its not optimal.
<div class='quotetop'>QUOTE (Jerstillman @ Mar 6 2008, 05:19 PM) [url=index.php?act=findpost&pid=30493]<{POST_SNAPBACK}>[/url]</div>
hahah yeah really. but no my car isnt dropped. and if it was dropped the camber would be even worse. its jsut weird that the factory comes with negative camber i know its not necessarily bad but its not optimal.[/b]
Wait... your not dropped yet you have substantial negative camber in the rear? Negative camber from the factory is little to non... something isn’t right if your stock suspension is inducing that much camber.
Do 3's have a torsion beam rear suspension, Macpherson struts or some type of proper suspension like dishwish bone or something else?
jerstillman
<div class='quotetop'>QUOTE (Colombia28 @ Mar 6 2008, 06:19 PM) [url=index.php?act=findpost&pid=30515]<{POST_SNAPBACK}>[/url]</div>
Wait... your not dropped yet you have substantial negative camber in the rear? Negative camber from the factory is little to non... something isn’t right if your stock suspension is inducing that much camber.[/b]
yeah the guy at the tire shop said and i mean i looked too and its bad, he said there was enough negative camber to provoke abnormal tire wear on my rear tires.
So is like half your tire bald (the inside) and the rest full of tread (the outside)? I was wondering why I couldn't get through the snow all to well this year.
Users browsing this forum: Bing [Bot] and 14 guests
