Car Died!
Does anyone have an OBDII Scanner I could use tonight? My car is throwing a cel and it won't start.
Mods:
Mods:
What the hell happened
<div class='quotetop'>QUOTE (RX 8 Ghost @ Mar 5 2008, 04:49 PM) [url=index.php?act=findpost&pid=30132]<{POST_SNAPBACK}>[/url]</div>
Umm. Want to pick me up and drive me down there and back up. That doesn't sound good at all. Go by checkers and see if they will loan one out. Leave you're credit card with them or something.
Does anyone have an OBDII Scanner I could use tonight? My car is throwing a cel and it won't start.[/b]
<div class='quotetop'>QUOTE (Greek8 @ Mar 5 2008, 04:57 PM) [url=index.php?act=findpost&pid=30138]<{POST_SNAPBACK}>[/url]</div>
Yes. Yes. No.
So you guys had it working again...and it just caput. Did you find anything out on 8 Club last night? MM get back to you at all?[/b]
Yes. Yes. No.
Mods:
Mods:
I think it is an ecu problem. It is freaking out because of all the changes.
<div class='quotetop'>QUOTE (RX-7 Chris @ Mar 5 2008, 05:01 PM) [url=index.php?act=findpost&pid=30141]<{POST_SNAPBACK}>[/url]</div>
That's what I was thinking to but I can't tell without an OBDII Scanner
I think it is an ecu problem. It is freaking out because of all the changes.[/b]
Mods:
Mods:
Have you tried disconecting the battery?
But the e-manage should be taking care of that....right? Unless E-manage is completely locked until drifter gets that serial from Greddy?
<div class='quotetop'>QUOTE (RX-7 Chris @ Mar 5 2008, 05:02 PM) [url=index.php?act=findpost&pid=30143]<{POST_SNAPBACK}>[/url]</div>
Ask Drifter
Have you tried disconecting the battery?[/b]
Ask Drifter
Mods:
Mods:
Why ask drifter? It's ur car? I'm lost...
It is at drifter's house now and he is working on it.
arctic_blue83
I have an OBD II scanner, but unfortunately I'm pretty far north of the Springs
Have you guys tried removing the eManage to see how the car would react? Really there's only a couple sensors that should effect your idle, your MAF & MAP.... I'm assuming the eManage would have to manipulate one of their values in order to alter your fuel trim. Where is your MAF sensor now located? Still right behind the filter/where the airbox used to be, or post turbo (<<rare, but I've seen weirder)?
