20b shortblock for sale...
- RX-7drifter
So who has tools to switch plugs and how easy is it?
- goldrocket
<div class='quotetop'>QUOTE </div>
Warning! This is a hand grenade!!! Mazda OEM gaskets are not for high RPM! 2mm Apex seals are stock size. No high RPM from 2mm unless they are hardened seals, and it should have been mentioned. Freezer plugs?!!?! My mother knows what they are actually called. And the process on the housings is not 'nitrating', it's called "nitriding". And polished rotor housings look pretty, but polished metal reatains a LOT of heat.
I have for sale my short Block 20b engine for sale. I do not have time any more to give to this project.
Paid 11k for this build with motor.
All new gaskets and seals all Mazda oem with 2mm seals.
Lightened rotors and assembly for high rpm.
New oil pump, chain and needle bearing, this motor has allot of new parts in it.
New 13b housings polished.
Street ported. Oil modification done.
All new freezer plugs and re-nitrated housings for long durability
Will come with 1 year or 24k mile warranty. 7500.00 $$[/b]
Al says
- Low Impedance
Users browsing this forum: Baidu [Spider] and 102 guests
1988 Rx7 Convertible: Current DD
1987 Rx7 Turbo II: motor down as of 10/28/08
