Parking Light Fiasco
Postby TheNewBlack » Wed Jan 23, 2008 9:14
Yesterday I got new front signal/parking lights...put them in...the drivers side parking light is stuck on way brighter than the other one....when i turn the signal on, the turn signal noise inside the car is going at turbo speed as well as the side signal and rear signal. I tried putting the stock bulb back in and now its doing the same thing. Hopefully this is something stupid im overlooking.... anybody have any idea whats up??
Postby MazdaTom » Wed Jan 23, 2008 9:14
Do all the lights actually work? I know on Chevy's, a fast turn signal sound indicated a burnt out bulb.
<div class='quotetop'>QUOTE (MazdaTom @ Jan 23 2008, 09:54 AM) [url=index.php?act=findpost&pid=19997]<{POST_SNAPBACK}>[/url]</div>
Do all the lights actually work? I know on Chevy's, a fast turn signal sound indicated a burnt out bulb.[/b]
Yeah the light works
Postby GR-8 » Wed Jan 23, 2008 9:14
Intresting. Fords are the same. Are you sure all the bulbs work. Front and Rear?
rx8ghost
Postby rx8ghost » Wed Jan 23, 2008 9:14
Did you check the fuses and wiring to the harness? I believe all cars' turn signal lights go turbo speed with they're about to go out or have.
Mods:
<div class='quotetop'>QUOTE (RX 8 Ghost @ Jan 23 2008, 01:17 PM) [url=index.php?act=findpost&pid=20031]<{POST_SNAPBACK}>[/url]</div>
Did you check the fuses and wiring to the harness? I believe all cars' turn signal lights go turbo speed with they're about to go out or have.[/b]
Checked the fuses and wiring...looks good to me. Hmmmmmmm. I made an appt. with mazda for tommorow morning, but i want to try to figure this out on my own today hopefully....im not sure if theyll give me shit for changing lights myself...it says not to in the manual.
<div class='quotetop'>QUOTE (TheNewBlack @ Jan 23 2008, 01:28 PM) [url=index.php?act=findpost&pid=20043]<{POST_SNAPBACK}>[/url]</div>
im not sure if theyll give me shit for changing lights myself...it says not to in the manual.[/b]
Are you f-ing serious?
It figures though. I heard the new BMW's don't have a dipstick to check the oil. The proper procedure for checking the oil is to bring the car into a dealership.
I like having new cars, but I don't like having the ability to work on them taken away. Especially for stupid stuff like light bulbs and oil.
Postby tsx_guy » Wed Jan 23, 2008 9:14
<div class='quotetop'>QUOTE (MazdaTom @ Jan 23 2008, 01:38 PM) [url=index.php?act=findpost&pid=20046]<{POST_SNAPBACK}>[/url]</div>
I like having new cars, but I don't like having the ability to work on them taken away. Especially for stupid stuff like light bulbs and oil.[/b]
yep the lights are to be handled by the dealerships...I heard about the BMW sans dipstick as well and it seemed to be an odd change....personally I don't like
relying on others to tell me when things are low.... :26fdf3e6:
Postby Colombia28 » Wed Jan 23, 2008 9:14
The turbo signal action is usually a result of A. burnt out bulb. B. blown fuse. or C. maybe wrong bulb.
<div class='quotetop'>QUOTE (Colombia28 @ Jan 23 2008, 02:15 PM) [url=index.php?act=findpost&pid=20066]<{POST_SNAPBACK}>[/url]</div>
The turbo signal action is usually a result of A. burnt out bulb. B. blown fuse. or C. maybe wrong bulb.[/b]
Well the bulb works...its pretty much stuck on bright mode, the parking light fuse looks fine...and the bulb # was exactly the same as the one I removed. :368a3915:
Is it in backwards?
Did the low intensity filament burn out?
<div class='quotetop'>QUOTE (MazdaTom @ Jan 23 2008, 02:59 PM) [url=index.php?act=findpost&pid=20077]<{POST_SNAPBACK}>[/url]</div>
Is it in backwards?
Did the low intensity filament burn out?[/b]
Is there a backwards? Ill check it out. Neither filament looks burnt out.
Thanks for all your suggestions BTW :6f1d77c8:
Postby SpeedRacer » Wed Jan 23, 2008 9:14
Randy the problem is you need a relay put in.
correction you need a resistor
http://www.mazda3forums.com/index.php?topi...94007#msg294007
<div class='quotetop'>QUOTE (SpeedRacer @ Jan 23 2008, 06:37 PM) [url=index.php?act=findpost&pid=20102]<{POST_SNAPBACK}>[/url]</div>
http://www.mazda3forums.com/index.php?topi...94007#msg294007[/b]
That thread looks like its about changing to LED lights....i have the stock lights in there right now...why would the stock lights all of a sudden need a resistor? :huh:
I dunno.. cause they're gay
