Calliing All Rotary Mecanichs
- goldrocket
Guido, you're still a postwhore thread jakcer! and colostomy bags are for poop, not pee! I think the word you were looking for is catheter. Anyway, Drifter...who started this post on a relevant subject...Make sure that if you are going to put a turbo engine together that you get good apex seals and if you can, turbo rotors. If you only plan a few pounds of boost you'll be ok with n/a rotors. A turbo from a tII with n/a rotors will work if you only run 5-7 psi of boost. but you will have to run premium gas and a knock sensor. but that amount of boost with a good street port and engine management should easily yield a dependable 300 hp. And I stress dependable. If you want more you will need to build a turbo rotary engine from the ground up, and use a bigger turbo for more volume and a little more boost. And once you go past 300 hp then you need to get a TII tranny and replace the rear end with a TII LSD. Don't forget the brakes. It's no fun to go fast when you can't stop. Oh, and by the way, I have had no trouble with a few muskrats, wrx's, and my favorite was the Audi TT. But I also kept an M3 BMW from getting around me too, and my car is not turboed yet.
Al says
- RX-7drifter
TII rear is stronger and it has a LSD
- RX-7drifter
Bunch of threadjackers... Laurel and Josh!! How are you guys gonna be racing, from a roll or a stop? EVO will rape you off the line so I hope its from a roll to give you a chance.
2007 Mazdaspeed3 Sport</span>
-Mazdaspeed Short Ram Intake
-HKS SSQV Bov
-Tein S-Tech Springs
-HKS SSQV Bov
<div class='quotetop'>QUOTE (SpeedRacer @ Jan 29 2008, 04:35 PM) [url=index.php?act=findpost&pid=21280]<{POST_SNAPBACK}>[/url]</div>
That's probably because he didn't know how to drive the EVO. What Time did you run.
Um Jack I don't know if you forgot or if you weren't there but I ****BEAT**** an EVO at Bandimere last summer off the line and at the finish[/b]
I knew that but i'm talking about a Turboed FD RX7 racing an EVO... slight difference of RWD vs. AWD. Albert can confirm that I walked away pretty easily from a tuned 2008 Nismo 350Z on the highway at a 40-50 MPH roll TWICE!! It was my friends 350Z that was at the Hamburger Stand, very sweet car. Our Speeds can keep up and take alot of others out there.
What are you or what do you think you're pushing as far as Hp RX7-drifter?
-HKS SSQV Bov
-HKS SSQV Bov
Josh, when you ran the 14 sec run did you have your EMS in?
-HKS SSQV Bov
-HKS SSQV Bov
Users browsing this forum: Bing [Bot] and 82 guests
