1970 Ford F250 Explorer
Re: 1970 Ford F250 Explorer
Postby speedjunkie » Fri Jun 24, 2016 9:14
OK sounds good. I'll look through what I have.
Postby RX-7 Chris » Thu Jun 30, 2016 9:14
I will be installing the fuel pump and heat shield from Eric this weekend hopefully.
Postby Shadowden » Thu Jun 30, 2016 9:14
Fun! This weekend is pretty general. Will food be provided?
Oh, this wasn't an invitation?
Shadowden wrote:Fun! This weekend is pretty general. Will food be provided?
haha
Postby RX-7 Chris » Mon Jul 11, 2016 9:14
My shift linkage is back together and I took the truck on a drive to Lowes. I need to do some final adjustments to the linkage because it is slightly off still. I also need to figure out why my left turn signal isn't working.
Postby RX-7 Chris » Mon Sep 12, 2016 9:14
I'm hoping the wife will let me spend some time this weekend working on the truck, finally getting the oil leaks fixed. lol
Postby Huzer » Mon Sep 12, 2016 9:14
Good luck! I know new baby time, it's tough to get stuff done. I have yet to spend a good duration of time in the garage on the car, definitely nothing like I did on the Miata, yet. Soon, hopefully.
Should have a fall tech day at your place and maybe get a couple of extra hands to help out.
Postby Shadowden » Mon Sep 12, 2016 9:14
In for fun garage day. Please have nice weather for it though.
Postby RX-7 Chris » Tue May 02, 2017 9:14
Since the work on the truck still hasn't gotten done, I'm going to try and work on it this weekend.
Postby RX-7 Chris » Wed Jun 14, 2017 9:14
Next week is my work on truck week. I'm taking time off to get stuff done since it never seems to happen on the weekend.
Postby RX-7 Chris » Thu Jun 22, 2017 9:14
I finally started to get something done on the truck. Intake has been pulled, cleaned, painted, and reinstalled. Tomorrow I need to clean, paint, and reinstall the valve covers. After that it is onto the oil pan and air cleaner.
Postby Shadowden » Fri Jun 23, 2017 9:14
Wow. That looks really good. Nicely done.
Are you going to patch the fan shroud?
Postby RX-7 Chris » Mon Jun 26, 2017 9:14
Shadowden wrote:Wow. That looks really good. Nicely done.
I am going to patch the fan shroud. I was really pissed when that happened. I had picked up a perfect original fan shroud out of the junk yard and not a month later a mounting molt worked its way loose. The shroud hit the fan when I was driving down the road. It is made out of fiberglass so it shouldn't be to hard to repair.
I still need to pull and reseal the oil pan. I also need to replace the plugs and points. I knew I had them but I couldn't remember what I did with them, turns out there were in a logical place in the cab of the truck, lol. Once that is all done, I have to put the new fluids into it and start it.
Postby Shadowden » Mon Jun 26, 2017 9:14
It really looks good!
Return to “Piston Vehicle”
