1970 Ford F250 Explorer
Re: 1970 Ford F250 Explorer
Postby RX-7 Chris » Thu Feb 25, 2016 9:14
My first priority is working on the RX-7 but as soon as I get that back together it is onto the truck.
I need to resize the Accelerator Pump Discharge Nozzle because when I hit the gas the truck sputters. I also need to get bolts for the lower front shock mounts. They mount to I-beams with rivets and they are warn so the mounts rattle, I will need to cut off the rivets and mount bots. One other thing I really need to get done is removing the one helper spring in the rear. All I can figure is it was added when there was a pickup bed camper. I just never got around to removing it.
Once I get all that done, it is onto the motor. Fixing oil leaks....
Intake manifold, valve covers, oil pan, and exhaust manifolds need to be pulled and gaskets replaced. Motor needs to be cleaned and painted.
Postby Shadowden » Thu Feb 25, 2016 9:14
I'm curious about removing the spring on the leaf pack. Let me know when you want to do that so I can come watch and hand wrenches.
Postby RX-7 Chris » Mon Jun 13, 2016 9:14
I was driving the truck a couple of weeks ago and when I got home I couldn't get it to shift into park. The problem turned out to be the Automatic Column Shift Collar. It is made out of pot metal and the inside snapped. I have a new one ordered and and it will be here Thursday. I'm lucky it is really cheap and available.
Postby speedjunkie » Mon Jun 13, 2016 9:14
You should get a forged one made so it never breaks again! lol
Postby RX-7 Chris » Tue Jun 14, 2016 9:14
I could buy quite a few $30 parts for the cost of one forged one, lol.
Postby RX-7 Chris » Mon Jun 20, 2016 9:14
My truck is mostly back together. I have the steering column all back together with the replacement part installed. I still have to reconnect the steering column wiring and the shift linkage under the hood.
I also have a new high flow Carter fuel pump. 120 gph, 5.5 to 6.5 psi. The stock pump is 45 gph so I really hope this fixes my fuel starvation problem at full throttle.
Postby speedjunkie » Mon Jun 20, 2016 9:14
Sounds like you need an anti-surge tank lol.
Postby RX-7 Chris » Tue Jun 21, 2016 9:14
It has a mechanical pump mounted to the side of the block, lol
Postby speedjunkie » Tue Jun 21, 2016 9:14
Oh it's pulling and not pushing. Got it.
Postby RX-7 Chris » Wed Jun 22, 2016 9:14
speedjunkie wrote:Oh it's pulling and not pushing. Got it.
Exactly.
The problem is modern fuel has alcohol in it (up to 10%) and the truck isn't designed for that. The alcohol can't handle the heat of an old motor and tends to turn to vapor. Alcohol has a much lower boiling point than gasoline.
Postby Shadowden » Wed Jun 22, 2016 9:14
Would wrapping the headers help control some of the heat close to the block?
Postby RX-7 Chris » Thu Jun 23, 2016 9:14
No headers to wrap. I just have cast iron exhaust manifolds.
I have wrapped the fuel line with tape. Anyone know where I can get heat shield sleeve for the 5/16" fuel line in town?
Postby speedjunkie » Thu Jun 23, 2016 9:14
I might have some big enough if it's long enough. Pep Boys on Academy near Platte has a decent variety of heat barrier products. Advance Auto Parts usually has some and maybe the O'Reilly on Academy between N Carefree and Austin Bluffs (Betty I think is the street). Laniers might have some. It really sucks that we don't have many speed shops anymore.
5/16" is the diameter? I'll look at what I have. Stop by tomorrow or sometime this weekend if you want. How long does it need to be?
Postby RX-7 Chris » Fri Jun 24, 2016 9:14
I'll give you a call when I get off work. I need 2 pieces 12" or so long.
Return to “Piston Vehicle”
