Community Autox Car
The forum to talk about hitting cones.
Saul_Good
Postby Saul_Good » Mon Nov 03, 2014 9:14
Shadowden wrote:What is wide? In the rear you looking for 10+? To counter oversteer, do you need similar width in the front? I assume the back of that thing is insanely twitchy.
Huzer, I'd drive it. It is STR competitive as it sits, with a better driver than me that is.
IIRC (i could be wrong) it doesn't have an LSD and would compete in STS. It would have a better chance there, than I ever would in STR.
Postby Huzer » Mon Nov 03, 2014 9:14
I'd probably have to get low profile sliders to make the driver's seat easier to adjust. It can be unbolted and repositioned, but that's kind of a pain. I plan on adding a matching FX1 Pro for the passenger side.
It's perfectly reliable to be driven to/from events (in my mind). I don't currently have adjustable coilovers and don't plan on getting them anytime soon. I do have FM sways and adjustable endlinks. I think overall it's got good parts on it. I plan on adding the FM Happy Meal clutch kit to the car over the winter.
Saul_Good wrote:IIRC (i could be wrong) it doesn't have an LSD and would compete in STS. It would have a better chance there, than I ever would in STR.
Correct, it does not have an LSD. If I swapped to an LSD, would that change the classing?
Saul_Good
Huzer wrote:Correct, it does not have an LSD. If I swapped to an LSD, would that change the classing?
Yes. I need to dbl check that as I 'think' the 1.6L would still keep you in STS. Currently my basic knowledge is Miata + LSD = STR
Postby Huzer » Tue Nov 04, 2014 9:14
Yesterday, we determined my car would be SSM, which I guess is some hooptie dooptie category.
Postby Shadowden » Tue Nov 04, 2014 9:14
street modified baby. Your fully fast and furious.
Brigdh
Postby Brigdh » Tue Nov 04, 2014 9:14
Huzer wrote:Yesterday, we determined my car would be SSM, which I guess is some hooptie dooptie category.
Chassis bracing?
Brigdh wrote:Chassis bracing?
Yep. Frame rails.
Return to “Autocross”
Users browsing this forum: Baidu [Spider] and 51 guests
