D Walker wrote:Eric starter signal from the switch rarely has anything to do with slow cranking as long as your getting some voltage to the starter solenoid to trip it. I would check, in order:
Starter- an starter that sometimes cranks fast and then sometimes slow can have damaged. Excessive or repeated cranking really heats up a starter and will damage it. We often joke it is the most often abused part on a rotary.
I have a new starter on the car, because I originally thought that was the issue.
D Walker wrote:Battery cables- I am not a fan of battery relocations, mostly because they are not often done well. For an RX7 I would used at least 1/0 welding cable. The positive cable needs to go to the starter, then to the fusebox, and I often redo the alternator wire as well. Running the cable to the stock battery cables (yeah, I have seen this done multiple times) is asking for issues. The Ground cable needs to go first to the chassis near the battery, then from there to the engine block, preferably near the starter, then to the chassis again, usually the firewall or near the fusebox. I only use copper lugs for all of this because the steel ones often used will rust and corrode and can make diagnosis very difficult.
I'm using welding cable but I'm not sure if it's 1/0. It's about 4 gauge in size, I know that. I run the positive cable to the starter and it ends there, but the stock cable from the fuse box to the starter is still in place. I used to run the cable to the stock battery cable/location, but changed it a year or two ago.
The ground cable is grounded to the chassis right next to the battery, and also to the transmission, but not in one loop. Each one connects to the battery. I also have two or three added grounds on the engine that I put on back around 2008. Those are from the HKS Circle Earth kit but I'm thinking about making some with welding cable to replace those also. I think the lugs I used are steel, but I'm not sure, and they're pretty new since I made new cables about a year ago.
How did you redo the alternator cable? From the alternator straight to the battery or what? I'm still using the stock cables for that.
D Walker wrote:Solenoid connection- its rare but I have actually seen the spade terminal on the wiring harness at the solenoid have issues with the wires being broken or the terminal itself being loose and making poor contact.
This might actually be my problem now that you mention it. When I put the starter back in, I noticed the spade connector that goes to the starter solenoid is a little loose. I tried to crimp the inner (metal) portion of it together to tighen it but it didn't work, so maybe I'll just crimp around the plastic as well when I get home. It's loose enough that it could slide right off probably. I hadn't thought of that being a possible cause. I should probably do a continuity check on that wire too while I'm at it.
RX-7 Chris wrote:exactly ding ding ding
basically every wire finds it way to a ground at some point. So if a power wire goes to a motor it than travels through the motor and out to a ground wire.
Now if the wire was disconnected at all connections and was still grounding out than there is a short.
Eric, Let me know if you need me to stop by this weekend.
So that makes me wonder why Zico's was showing OL for the ST wire, but mine showed continuity. Now I'm wondering which one is right.
OK thanks! I plan on diving into this at least part of this weekend. I want to get this sorted out and it's starting to drive me crazy since I've checked so much stuff so far.
