Lately there's a weird muffler-related vibration aound that happens, you can hear it from the interior / below, happens when in motion
Could it be a loose muffler-body-clamp?
Driving it a very long distance soon and would like to fix it asap
the "what's that sound game" part 3
start with the exhaust mounts. Also check and see if the heat shield is coming loose and rubbing the exhaust.
If everything with the exhaust seems to be okay, check the rear wheel bearings. Sometimes when it sounds like it is coming from right under you, it is actually in the rear.
Thanks for the advice, im pretty sure you guys are right.
Took a closer look today but I can't see much without getting the car lifted, I did notice one part where the heat shield looks loose and I tried tightening the bolt but its stripped.
Leaving tomorrow and going to tack on a few thousand miles (will be at 100k+ on return), then may sell it and get a gen2 or another fun toy, i'm debating taking my car-title on this trip
Users browsing this forum: No registered users and 100 guests
