Saul_Good wrote:Operation Rotary Rebirth has commenced
Your making the wild ASSumption it ever stopped...
millertime wrote:Pretty sure I have a stock one in a box somewhere. I can bring it down with me this weekend if you need it.
$crillaTor wrote:If he ^ doesn't have a stock ECU, I have one you can borrow. Just let me know. I could meet you this afternoon if you want.
FDEEZ wrote:That little ignitor performs actions at such a fast rate, that it may be difficult to determine if it's working correctly. You may be getting "some" spark, but you may not be getting a "high-voltage" spark.
The best option for you, IMO, would be to borrow a known "good" ignitor & see if the car starts. If that doesn't work, borrow a known "good" set of coils and see if it starts. From there, a known good ECU and etc. Swapping out known "good" parts is a lot quicker than ensuring/testing continuity, resistance, voltage, etc., of each part or the signal between the ECU to each individual part is within spec. But you can do that too if you're adventurous :-)
Hopefully you're not going through all this only to find out your fuel feed/return lines are mixed up, j/k
D Walker wrote:Your making the wild ASSumption it ever stopped...
Eric,
Attached to this email are the flow test results for the ID725s & ID2000s that were sent in to be cleaned and inspected. As you will see, they are still a relatively tight and linear matched set, with average deviation across the entire operating range coming in within our spec of +/- 1.5% .
I will be calling you shortly to go over these results, as well as discuss options for payment / return shipping. Talk to you soon.
