Alex's XTi
Postby Shadowden » Mon Mar 17, 2014 9:14
_AlexTM wrote:What do you mean?
So you can take the front plate off and not have visible holes in your bumper for pictures.
Postby RX-7 Chris » Mon Mar 17, 2014 9:14
looks good
Postby Huzer » Mon Mar 17, 2014 9:14
I like it. You've got a nice ride, there. My wife always thinks I'm crazy when I point out this generation of Forester and say that I like them. She doesn't share my wagon love, though.
_AlexTM
Postby _AlexTM » Mon Mar 17, 2014 9:14
Shadowden wrote:So you can take the front plate off and not have visible holes in your bumper for pictures.
Ohh yeah, im going to get one of those license plate delete things in the near future!
SOLD 2004 Mazda3 hatch
_AlexTM
RX-7 Chris wrote:looks good
Huzer wrote:I like it. You've got a nice ride, there. My wife always thinks I'm crazy when I point out this generation of Forester and say that I like them. She doesn't share my wagon love, though.
Thanks to both of you! Its so much fun. Yeah this is my favorite generation by far, the newest ones arent bad though!
_AlexTM
Postby _AlexTM » Tue Mar 18, 2014 9:14
Yup, so i got my boost gauge installed, it works great. Now the issue is trying to find a boost leak or if i need a new turbo (has 130k) as im only hitting 8lbs TOPS, 5-7lbs consistently. Grr. Any ideas?
Looks great though
And another picture i snapped yesterday
Postby I`m Batman » Tue Mar 18, 2014 9:14
Lookin' good!!! I like!
Postby RX-7 Chris » Tue Mar 18, 2014 9:14
You can pressurize the system with compressed air and use a spray bottle with soapy water.
http://www.turboboostleaktesters.com/servlet/the-HOW-TO-BOOST-LEAK-TEST-101/Categories
Dwduc
Postby Dwduc » Wed Mar 19, 2014 9:14
Or spray some ether around the boost hoses/couplings at idle. If you spray a leaky spot the engine will rev
Mortose
Postby Mortose » Wed Mar 19, 2014 9:14
Dwduc wrote:Or spray some ether around the boost hoses/couplings at idle. If you spray a leaky spot the engine will rev
That would be if there was a vacuum leak.
Alex, what is the boost target that you should be hitting?
If i were you i would spend the $8 for all the stuff from home depot to build a boost leak tester.
Postby erod550 » Wed Mar 19, 2014 9:14
_AlexTM wrote:Yup, so i got my boost gauge installed, it works great. Now the issue is trying to find a boost leak or if i need a new turbo (has 130k) as im only hitting 8lbs TOPS, 5-7lbs consistently. Grr. Any ideas?
That actually sounds about right. Stock boost is only 10-11psi and you're going to see less boost being at altitude. Just like in an MS3 stock boost is around 15psi and you only see 12 on a stock one at altitude.
_AlexTM
Postby _AlexTM » Wed Mar 19, 2014 9:14
Yeah target boost is 10-11 or so. I tightened some clamps down and now see 9 consistently and it tapers down to 5 and holds. I forgot about the altitude factor so I'm technically exactly where I should be. Slow. Haha. I probably will make the boost leak tester in any case it'll be handy
_AlexTM
Postby _AlexTM » Sun Mar 30, 2014 9:14
My friend Zach and I at the Forester Nation meet we hosted today. Had fantastic turnout. Including some speed3's owned by Chris and Casey
DV5420
Postby DV5420 » Sun Mar 30, 2014 9:14
Sweet shot!
_AlexTM
Postby _AlexTM » Tue Apr 01, 2014 9:14
"Help, ive fallen and i cant get up"
Return to “Piston Vehicle”
Users browsing this forum: No registered users and 19 guests
