'92 Miata: Budget Project Car
Saul_Good
Postby Saul_Good » Sun Mar 09, 2014 9:14
roninsoldier83 wrote:Just curious, does your head/helmet clear the bar with that setup? If so, by how much? And I suppose more importantly- how tall are you? :lol:
Sorry to yet again jack your thread Tim. :D
Yes everything clears for me and then some. I'm 5'9" tho B)
roninsoldier83
Postby roninsoldier83 » Sun Mar 09, 2014 9:14
Saul_Good wrote:Yes everything clears for me and then some. I'm 5'9" tho B)
Ahh, I see. How much did your Sparco Rev seat lower you (if at all)? At 6'2" I'm thinking it'll be just a bit tougher for me and I can use all the help I can get (i.e. lower seats, ect)!
Mine: 2015 Subaru WRX
Hers: 2013 Subaru WRX
Postby Shadowden » Mon Mar 10, 2014 9:14
Nothing better than being average height!
Postby Huzer » Thu Mar 13, 2014 9:14
Carpet arrived today. Now I'm itching to get it installed, along with the frame rails and finishing up mounting the seat (I haven't drilled the floor yet for the rear bolts. The position is currently where I want it. Really, I should wait for the roll bar to arrive to make sure I don't have to make any further modifications to the seat position in order to fit how I'd like.
Postby Huzer » Fri Mar 14, 2014 9:14
Woohoo...roll bar to be delivered on Tuesday. I'm a happy camper. Looking to install the following weekend, so the 22/23rd.
roninsoldier83
Postby roninsoldier83 » Sat Mar 15, 2014 9:14
Unfortunately the wife has plans for us that weekend/Sunday. Sorry buddy.
Saul_Good
Postby Saul_Good » Sun Mar 16, 2014 9:14
In case you were curious, this is how much clearance you'll have with a HT and/or SoftTop with the Bossfrog Rollbar.
Postby erod550 » Sun Mar 16, 2014 9:14
Pics no worky :\
Saul_Good
Postby Saul_Good » Mon Mar 17, 2014 9:14
I don't know why it worked but here's another one. I also added one to the original.
Postby Huzer » Mon Mar 17, 2014 9:14
Weekend plans:
Install roll bar
Install FM frame rails.
Finish drilling/mounting seat
Install carpet
Install SS clutch line
Potentially install new slave. Receipts claim the current one is new.
Fun stuff. I need to get the garage in order prior. Made more difficult by storing my bro-in-law's 911 this week. It'll be gone either Thurs or Fri, so I'll have room back.
Postby Huzer » Wed Mar 19, 2014 9:14
Woohoo!
Postby Huzer » Sun Mar 23, 2014 9:14
Thanks Ron, for dropping off the slave cylinder and the lines. Awesome!
The rollbar is installed. Other than fiddling with getting the seat tower bolts aligned, the lower ones were trickier than the top, I had no issues. I had to grind the anchor on the seat belt reel anchors to get it to align in front of the roll bar feet. Even before getting the bolts in that anchor the rear feet, it felt solid. I havent driven the car yet. I havent installed the frame rails yet, so obviously the carpet isnt in either. I'll be back together by the end of this week.
roninsoldier83
Postby roninsoldier83 » Mon Mar 24, 2014 9:14
That's good stuff buddy! How long did the roll bar end up taking you to install?
..... and of course: pics or it didn't happen. :D
Postby Huzer » Mon Mar 24, 2014 9:14
I'll get some pics today. The install time for me will be skewed by the fact that my interior was already stripped. Thus, it was really the effort of jacking up the car, pulling the splash shield, and drilling the additional 10 holes thru the car. I didn't have nearly the headache some have had aligning the seatbelt tower bolts.
At this point, I haven't reassembled the interior trim pieces yet, I'm about 2 and a half hours into the install. I'm hopeful I can get in the garage today to finish up the trim portion of the install and maybe get the frame rails installed. I still need to go get some undercoat to seal the holes I've drilled.
roninsoldier83
Sounds like a plan... If you're not done installing everything by this Sunday (the 30th), let me know and I can probably stop by & lend a hand... Assuming I don't get held over again at work, like I did yesterday haha.
Return to “Piston Vehicle”
