Rear sway bar clunks
DV5420
Postby DV5420 » Fri Feb 28, 2014 9:14
I can not seem to fix the clunks coming from the rear of the car. I assume it is the Mazdaspeed3 rear sway bar, because that's the only thing that isn't stock.
I've tried the following to no prevail:
New sway bar bushings & brackets.
Tightening of the end links & brackets.
I don't believe it is the endlinks, They are basically brand new OEM.
Has anyone had any problems regarding read end clunks? (Note: My car is a Mazda3 with Mazdaspeed3 rear swaybar & endlinks)
Postby geo2maz » Fri Feb 28, 2014 9:14
That sucks, i know your pain,
Do you still have the stock Mazda3 sway bar? If so I'd try switching back to that... Otherwise maybe shocks?
Postby Shadowden » Fri Feb 28, 2014 9:14
I didn't have any clunking when i had an MS3 sway on my MZ3. When tightening the endlinks, is the car on the ground or on stands? I recall it needing to be on the ground (compressed). Are you supporting the tightneing nut with a hex key? From there, I gues I would check the shock mounts for tightness.
DV5420
geo2maz wrote:That sucks, i know your pain,
Fortunately I do, I'll swap them out this weekend & see if there's any noticeable noise.
Shadowden wrote:I didn't have any clunking when i had an MS3 sway on my MZ3. When tightening the endlinks, is the car on the ground or on stands? I recall it needing to be on the ground (compressed). Are you supporting the tightneing nut with a hex key? From there, I gues I would check the shock mounts for tightness.
Hmm, I didn't know that. My car has always been on a lift or lifted with a floor jack. I do use a hex key when tightening the endlinks.
I'll have to find somewhere where I can back my car up against a ledge or something because I can't fit under the back, with it sitting so low.
Or have a little person like me reach under there. Are you slammed on coilovers or something? I was lowered on eibach springs and had no problem reaching.
Just the end links. I don't think the attachment of the sway bar to the sub frame matters.
Another silly possibility...is it possible your hatch floor covers are just bouncing and making a knocking noise (silly, I know).
AuroraAxela
Postby AuroraAxela » Sat Mar 01, 2014 9:14
He's in a sedan like mine, and also on eibachs.
_AlexTM
Postby _AlexTM » Sun Mar 02, 2014 9:14
Struts
SOLD 2004 Mazda3 hatch
Postby RX-7 Chris » Mon Mar 03, 2014 9:14
DV5420 wrote:I'll have to find somewhere where I can back my car up against a ledge or something because I can't fit under the back, with it sitting so low.
Shadow is right about the weight needing to be on the car.
The way I have found to be easiest is the set the car onto ramps using the floor jack. I assume you aren't able to drive up onto ramps (I'm not either).
Postby Huzer » Tue Mar 04, 2014 9:14
Concur with vehicle being on the ground/ramps for the end links. Nearly all of the clunks I've had suspension wise have been endlinks. If tightened on a lift, you're preloading the bar once it's on the ground. Not quite as big a deal for non adjustable endlinks, but still an issue. The others (for me) which seem unlikely in your case have been bad A arm bushings, sway bushings, loose shock mounts.
Postby erod550 » Tue Mar 04, 2014 9:14
Yep, jack the car up, loosen the suspension bolts (any that you tightened down without a load on them), put rear wheels down on ramps, tighten bolts to spec. I know it's not a Mazda but I have extensively modified the rear suspension on my Mustang and have avoided noise/clunking by doing it this way.
DV5420
Postby DV5420 » Tue Mar 04, 2014 9:14
Thanks everyone for the suggestions. I'll try the ramp thing this weekend.
