I will get pics later, or will send pics of anything via email or text, just ask
Went through a bunch of stuff I have cluttering the shop and have the following I could get rid of if someone out there needed it, everything is make me an offer-
2 sets of stock FD twin turbos, housings etc. are in perfect condition, no cracks or erosion, some shaft play perfect set of buildable cores, make offer!
perfect, uncracked FD stock twin turbo manifolds, if you want I can throw in the turbos, which are probably junk but could be rebuilt but the real value is if you have good OEM turbos but cracked manifold, have the vacuum pots etc. if you want those as well, make me an offer!
I have half a dozen e-shafts, including S4, S5, FD, and RX-8, message me with what you need
Various front covers, oil pans, etc. for virtually any 13b engine
Very decent OEM FC oil cooler
1 set, meaning a pair, of reman FC Turbo 4-piston front brake calipers, still in boxes, were spares for the pikes peak car
1 set of Mitsubishi GT VR-4 front brake calipers,old school budget FD upgrade, might be able to use on fc as well, never tried
FC and FD air pumps
FC rear "crossmember"
FC front and rear suspension pieces, all I have left is 4-lug I think
Fc fans and fan shrouds
At least one FD down pipe, jet hot coated
FD Efini and Cosmo alloy charge pipes, couple of sets, let me know what you want/need
Stock FD SMIC in very good condition, under 30k miles when removed
FC OEM Intercooler (I think I still have it)
FD/Cosmo Stock throttle body elbows, yes the plastic ones
FD stock trans, in good condition
RX-8 trans missions, s1 and S2, most of them fresh rebuilds
Rx-8, FC and FD stock flywheels, might also have nearly new clutches still hanging around
Misc injectors, RX-8, FD, FC- S4, S5, turbo and non, all USED
at least one, maybe two OEM FD RX-7 ECU's
S4 NA ECU
Maybe an S5 T2 ECU, have to check
FC Coils, NA and Turbo
Bunch O RX-7/ Rotary stuffs for sale
- $crillaTor
