Humming noise from the passanger side
christi
Postby christi » Tue Jul 23, 2013 9:14
Anyone have had this happened to their Mazda 3? This magically started when I came back from vacation after letting a friend house sit... and supposely never used my car... (right). Anyway, between 10-20mph it's a low but deep humming, if I go from 20-75mph for speed limits... it is louder and a deeper humming. Also when I turn left or right it'll "click", which I hope that made sense. Would anyone know what this is?
I know going to the Mazda dealership is probably going to be a waste of time tomorrow after work, BUT I need to know :/ If anyone is in Pueblo, and wants to give it a shot tomorrow afternoon/evening, I'm willing for to take a shot...
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
Brigdh
Postby Brigdh » Tue Jul 23, 2013 9:14
Whens the last time you checked your wheel bearings?
christi
Postby christi » Wed Jul 24, 2013 9:14
I was thinking the same last night. Or a CV joint. Ill be going to Mazda today...the to get a quote to et quotes elsewhere too I guess. But do you believe that's it?
13B n/a Street Port
Goopy performance
2005 Mazda 3
Brigdh
Postby Brigdh » Wed Jul 24, 2013 9:14
That would be my first guess. CV joint would be another possibility. It seems likely that its a drivetrain component since it occurs when the vehicle is moving. Its probably after the final drive (diff) if it gets louder with road speed and not engine speed. Clicking when turning indicates a change when the part is either loaded or moved to a different orientation.
Wheel bearings are known for "clicking" when they badly need service, but a CV joint also meets the above observations. Either one should be fairly easy to diagnose.
christi
Awesome. would this also be a issue if I haven't had my 30k and 65k checkup yet on the car? She has 90k miles on her.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby erod550 » Wed Jul 24, 2013 9:14
I don't think a wheel bearing would have been replaced during 30k or 60k maintenance. I also don't think they even inspect them at those intervals but I could be wrong. But you could be heading for other issues if you've never done any of the maintenance on the car. But my guess would be wheel bearing also for this particular issue. Sounds just like what my Miata was doing when I first bought it and that was the cause.
whobeyou
Postby whobeyou » Wed Jul 24, 2013 9:14
Wheel bearing all the way...If you hear it clicking when you're turning, it's because there is too much pressure on the bearing and it can't properly spin the wheel. Honestly, the clicking is a sign of it going out very soon. I'd replace at least the fronts as soon as possible. My friend had a cougar and it started clicking, she let it go for a few months and the wheel locked up on her one day while she was driving.
Brigdh
Wheel bearings are supposed to be inspected at 30k according to every service schedule I've ever seen. 60k typically ends up being a 30k service plus a few additional things. I could see it being easily skipped by a lazy tech though.
Also, I recommend servicing both sides. Usually when one side goes out, the other side will fail in a few months. The bearings themselves are usually fairly cheap, the service might cost a bit if there is a need to press them in or out, but for the most part getting both sides done won't be too expensive and its cheap insurance/comfort. If the wheel doesn't lock up when the bearing fails, the other failure mode is the wheel falling off, which is a very bad thing to happen at speed.
christi
Yeah, I have a appiontment on Friday around 4p, hopefully I get off work in time. They said 80$ to check and 225$ for the wheel barring... Is it recommended to do both sides then?
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby erod550 » Thu Jul 25, 2013 9:14
Brigdh wrote:Wheel bearings are supposed to be inspected at 30k according to every service schedule I've ever seen. 60k typically ends up being a 30k service plus a few additional things. I could see it being easily skipped by a lazy tech though.
Thank you for clarifying. I wasn't sure.
And yea I ended up replacing 3 out of the 4 when it started happening on mine. Seemed like once I replaced one, another would start making noise.
christi
Postby christi » Thu Jul 25, 2013 9:14
I'll keep ya'll updated then on what it was. I'll probably do the 60k service too...
13B n/a Street Port
Goopy performance
2005 Mazda 3
Andyscums
Postby Andyscums » Fri Jul 26, 2013 9:14
I had a 3 hatch before my speed and it was a wheel bearing. Sounds similar to the noise mine was making as well.
christi
Postby christi » Fri Jul 26, 2013 9:14
Funny story, it's neither of those - it's the motor mount and it'll be about312$ to fix it - will be done on Thursday.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby kingtut » Fri Jul 26, 2013 9:14
Worst diagnosis....evar.
Glad you're getting it fixed.
Andyscums
Postby Andyscums » Sat Jul 27, 2013 9:14
Whoops.
Users browsing this forum: Google [Bot] and 175 guests
