1970 Ford F250 Explorer
Postby Huzer » Thu Jan 31, 2013 9:14
Looking good...I still think we should've raced last weekend. Old school Ford vs new Toyota. Would've been fun.
Postby RX-7 Chris » Tue Apr 30, 2013 9:14
My heater core just went last night and spilled coolant all over the passenger floor. Just in time for tomorrow's storm, lol.
It is a $20 part and about an hour install. The problem is it will take a few days to get.
Justin
Postby Justin » Tue Apr 30, 2013 9:14
Really? I'm surprised. The heater core for my '71 Bronco can usually be found locally with a little calling around. Might even be the same part.
It looks like you are right and NAPA has it in stock.
I had originally checked Autozone and O'Reilly.
Postby kingtut » Tue Apr 30, 2013 9:14
RX-7 Chris wrote:It looks like you are right and NAPA has it in stock.
Rookie mistake. Happens to the best of us..
Justin
It's the best part of owning an old American truck. Parts can be bought anywhere and are dirt cheap. The calipers when I did my disc brake swap cost me $20 each.
Postby RX-7 Chris » Wed May 01, 2013 9:14
true. I just bought a brake master yesterday. It will be in this morning and cost me $15.
I ended up just ordering a heater core from Autozone. I couldn't make it to NAPA before they closed. Everything should be here by 10am this morning.
Postby speedjunkie » Wed May 01, 2013 9:14
kingtut wrote:Rookie mistake. Happens to the best of us..
LOL
NAPA does seem to have more OEM parts in stock, but their hours aren't the greatest compared to the other stores. I have very little time to make it there after getting off work.
At least your car is about finished, Chris! lol
Postby RX-7 Chris » Mon Jun 10, 2013 9:14
I replaced the brake master and booster over the weekend. I need to still give the brakes a good flush.
I still haven't installed the heater core after all that.
Postby RX-7 Chris » Thu Jun 12, 2014 9:14
I'm back working on the truck again. I pulled the carb last night and started rebuilding it. I'm also converting it to Ford linkage and adding an electric choke. I'll be done with it tonight.
This weekend will be the front brakes and the heater core. I'm going to see what else I can get done.
Justin
Postby Justin » Thu Jun 12, 2014 9:14
You may want to do the front wheel bearings while you've got the brakes off. It's absurdly easy.
Postby RX-7 Chris » Fri Jun 13, 2014 9:14
Well I rebuilt the carb and everything looked good last night. This morning I noticed it is leaking from the fuel transfer tube. Hopefully I didn't chew up the o-ring when I installed the tube.
Justin, I'm not pulling the rotors when I work on the brakes. I replaced the bearings a few years ago. I'm just pulling the calipers so I can press in a sleeve where the calipers mount. The caliper mounting bracket isn't available and the existing ones are ovaled out so the calipers have up-down play and rattle. Power front disc brakes on a 1970 truck is very rare so finding good used parts in impossible.
Postby RX-7 Chris » Mon Jun 16, 2014 9:14
I fixed the rattle, the sleeve worked. I replaced the brake caliper guide pins and I ordered a hardware kit.
Next weekend I'll replace the pads and the hardware. It really isn't easy to find parts for this truck.
Overall the carb is working great. I was able to find a kickdown rod (small tranny mounted piece) at the junk yard so now I have a working kickdown. I still need to work on the jet size. I also need to run a ignition power for the electric choke.
Next on the list is the power steering lines and the heater core.
Postby RX-7 Chris » Mon Jul 21, 2014 9:14
I worked on the truck over the weekend. The tranny drip turned into a tranny pour last week. The tranny was pulled and the pump seals are being replaced today. I'm homing to have the truck done this evening.
Postby RX-7 Chris » Wed Jul 23, 2014 9:14
Well I got bad news last night. The tranny is shot and needs a rebuild. One thing that is impressive though is the tranny is from the late '60s and has never been rebuilt. The tranny shop said it is out of a motor home not a pickup and is very rare.
Return to “Piston Vehicle”
