My New Toy
I'd be up for a finished party
I started to work on the louvers. I drilled the rivets and pulled the braces. I need to bring the braces to a welder to have the cracks in the aluminum welded. I plan to drop it off on Friday.
Went and looked at the car after work yesterday. Not much to update.
Louver repair:
The louvers are all aluminum and riveted together. All the rivets needed to be replaced. I picked up a pack of 100 rivets. They are aluminum coutersunk 1/8", grip range .063-.125, hole size .129-.133.
The braces that support the center were cracked. I drilled the old rivets out to remove the braces. I dropped off the braces at the welder and should have them back next week. I took some before pics of the louvers that I will post tomorrow.
The cracked braces:
The cracked braces:
The louvers will be painted. I picked up this: http://www.eastwood.com/trim-paint-and-self-etch-primer-kit.html
The before pics of the louvers:
Drilling the rivets:
The supports welded:
Progess has been made on the car. The rust is all repaired and looks great.
Also I did all the rear suspention. The rear suspension has all poly bushings and is all cleaned and painted.
Rear control arms and watts links with bushings removed before paint:
Painted:
Painted:
Driver's side rust repaired:
Passenger side rust repair started:
Passenger side finished:
finished wheel wells with new bushing and cleaned and painted (springs are now cleaned)
sway bar finished:
The rear almost done:
The rear finished:
The rear finished:
- MtnHighRX-7
MtnHighRX-7 wrote:Really looking Great Chris. I can't wait to see it in person. You are the FB expert for sure, after all the work you've done.
Thanks.
I still have those seals for under the hood to give you. they've been sitting in my garage for over a year, lol.
Users browsing this forum: Google [Bot] and 50 guests
