So I cleaned out the garage today and got rid of a bunch stock FD parts. I also had to move the FD out to the street temporarily while cleaning the garage, which gave me an opportunity to test another "fix" for my hot starting issues...
This was actually thought up by Matt, but it was that I didn't use heavy enough gauge of wire when relocating my battery to the trunk (I used 8g). The theory is simply not enough juice is getting to the starter because of the long run coupled with the smaller gauge wire, the starter isn't able to spin fast enough and potentially the ECU/injectors/coils aren't getting full power, either.
Luckily, testing the theory proved pretty simple. I drove the FD around, parked it on the street and pulled my VW in front. Shut the FD down, attempted a restart, and it was doing the same no hot start, so I successfully replicated the issue. Jumper cables out, I jumped the VW to the FD's main where the battery wire connects and grounded.
Attempt to restart, and wow! The starter spun at least twice, if not more, faster. I normally monitor 200-240rpm while cranking normally, hooked up to the VW's battery I was seeing 500-600rpm. At first it didn't start, but it really wanted to. I looked at the AFR gauge and it was really lean (19:1) so I added a little more cranking fuel and bang! The engine fired right up! I was really ecstatic.
So I think I'm going to order some 0g power cable to redo the battery wiring with. If that doesn't do the trick, I may just have to get a new, larger full size battery and mount it somewhere else in the hatch.
My new car!
Yeah, I've heard that's about where it supposed to be, but 500rpm isn't hurting anything. I honestly think the starter motor isn't spinning the engine to 500rpm, but to 250 and the combustion process catches so fast it bounces right up when my gauge reads it.
The other problem was my current setup is spinning the engine to 250 to start with, then it quickly tapers down to about 180-160rpm. With the FD jumped, I was getting 500rpm right off the bat with the engine start instantly. Regardless, I'm taking it as a good sign haha.
Yeah, its probably catching right away and showing a "fake" value of 500. Starters burn themselves out if they spin too fast (too much current flowing though it), and if they can't disengage when the engine takes over, you can even slag the entire starter to the bell housing. It happened to me once on a short road trip in Wisconsin and really sucked.
I'll have to keep the wire gauge in mind if I decide to relocate the battery in one of my FCs. A few pounds of wiring by running "thin" is not worth starting problems.
Haven't updated in a while, the FD has been sitting in the garage tucked away while we got snow.
Since the battery testing with jumping the car, I ordered some high quality 0/1g power cable and terminals. Today, I ran the new heavy duty power cable replacing the 4g cable I used to wire it up. Had to get a little creative with the routing but got it done.
Started the car up and the starter spun much faster than before- sounded healthier for sure. Fired right up. Ran great without issue, getting full voltage between the battery and alternator.
Let it warm up, shut off the engine, attempted to restart. Fired right up again! Good news! Although, it would usually do that before (without driving it would usually restart), so the real test will come tomorrow when I drive it around and see what happens. Here's hoping I finally fixed this!
