The S2000
Postby Shadowden » Fri Nov 02, 2012 9:14
Also, I am planning on using either a large socket and hammer or a pair of fender washers and a bolt (cheap seat tool) to seat the new seals. Should there be any kind of lubricant or anything used?
SecondGenPAt
Postby SecondGenPAt » Fri Nov 02, 2012 9:14
windex would be a perfect lubricant. Soak the area with it and press the new seals in. As the windex dies it evaporates, leaving nothing behind.
Hakuna Matata
Postby RX-7 Chris » Fri Nov 02, 2012 9:14
Windex does work for this kind of thing.
Postby Shadowden » Sun Nov 04, 2012 9:14
Spent some more time with my stock wheels today. I got another wheel painted and the other two rough sanded with 150 grit. I don't really want to mess with wetsanding them, so I think I am going to try just polishing them first with cut, then swirl. Probably won't do much.
I also spent some time prepping the tubing that will eventually become my strut tower brace. Basically sanding all of the rust off of them. Also took a file to the seam of the cross bar to make it all disappear.
Postby Shadowden » Tue Nov 27, 2012 9:14
winter tires are getting mounted on the painted stock wheels tomorrow.
Changed the oil this past Saturday. Not a whole lot else to report other than I have some interior bits coming in soon...
Postby geo2maz » Tue Nov 27, 2012 9:14
will you wait for the first storm to put them on the car or are you going ahead with install?
pictures tomorrow? :)
planning to install preemptively. I was a boy scout..."Be Prepared".
I'll get some pics tomorrow. If I get them on in the light. Otherwise, Thursday.
Postby Shadowden » Thu Nov 29, 2012 9:14
Winter/track wheels with winter tires mounted. Painted with VHT Satin Black chassis and roll bar paint. Not bad for winter wheels. Stock Honda S2000 AP1 wheels made by Enkei.
AuroraAxela
Postby AuroraAxela » Thu Nov 29, 2012 9:14
Those look good. You were right about the silver centercaps. They work well with that setup!
_AlexTM
Postby _AlexTM » Thu Nov 29, 2012 9:14
Very nice dude
SOLD 2004 Mazda3 hatch
Postby geo2maz » Fri Nov 30, 2012 9:14
Sweet! So were those the ones you painted? For some reason I thought you were getting them in blue... But I'm a teensy bit durnk at the moment...
Either way, coo!
Postby kingtut » Fri Nov 30, 2012 9:14
Lookin' good Mr. Sir!
Postby RX-7 Chris » Fri Nov 30, 2012 9:14
looks good.
It's hard to tell in the pic. did you do the blue lip?
Postby ~Barn~ » Fri Nov 30, 2012 9:14
Looks sharp!
Image 720.935.6438
Postby tsx_guy » Fri Nov 30, 2012 9:14
geo2maz wrote:Sweet! So were those the ones you painted? For some reason I thought you were getting them in blue... But I'm a teensy bit durnk at the moment...
Either way, coo!
when are you not?
Return to “Piston Vehicle”
