Nice! I really need to do this soon, I want to burn through the rest
Of my winter tires before I buy new ones, this would b perfect!
Thanks for uploading the vid
The Miata
- Saul_Good
Some vids from trackday a couple weekends ago.
http://youtu.be/FnLN7o7PetM -- chasing a turbo NA Miata
http://youtu.be/WAoW2sKsqTE -- New personal best after having coilovers rebuilt
http://youtu.be/bo2Owmm6tLY -- Some fun chasing a 335i
_________________
_________________
Saul_Good wrote:Had a nice little leak going under the valve cover.
My valve cover gasket appears to be leaking too. Lots of moisture around the gap after driving. I have all the stuff to redo the water pump and timing belt, including a new valve cover gasket, it's just such a huge job that I have been putting it off, ugh.
So what was the deal with that 335i when you took the inside of the one corner where it looked like he moved out to let you pass, then cut back in? Seemed like something was off there. I ask so I don't end up in a similar situation when I do make it out there. I have a bit of a temper and would like to know when I mess up vs. someone else when my car is at stake.
- Saul_Good
Shadowden wrote:So what was the deal with that 335i when you took the inside of the one corner where it looked like he moved out to let you pass, then cut back in? Seemed like something was off there. I ask so I don't end up in a similar situation when I do make it out there. I have a bit of a temper and would like to know when I mess up vs. someone else when my car is at stake.
I don't know. I was confused too. Maybe he didn't see me.... i was surprised but it didn't phase me too much cept for my momentum that i had goin into that corner. I'm guessing that was the line he wanted to take (wide then apex in) and didn't know I was there too *shrug* Just gotta watch and be ready
Saul_Good wrote:I don't know. I was confused too. Maybe he didn't see me.... i was surprised but it didn't phase me too much cept for my momentum that i had goin into that corner. I'm guessing that was the line he wanted to take (wide then apex in) and didn't know I was there too *shrug* Just gotta watch and be ready
I don't know, seems like your pace picked up a bit after that...
Thanks.
I thought maybe it was the one corner where that's the line since it's a decreasing radius turn, but yea turn 2 is not like that so not sure what was going on there, unless he didn't see you coming inside there. He obviously wasn't too familiar with the track because he took turn 1 waaaay slow (I did too at first not realizing how much speed you can carry into it).
- Saul_Good
I hadn't been to the track since January. I was having withdrawals. Also tried a different mounting location. Sorry if its shakey.
http://youtu.be/a5ghjmpcFcw
http://youtu.be/UEO8nIL-pbE -- This one is on the windshield.
The track was wide open again. Managed to get 110 miles of seat time.
