Car is running!!!
Postby tbot » Thu May 24, 2012 9:14
Fmic showed up today...so I'll be getting that installed with a custom oil cooler this weekend. After that its just trying to get as many miles on the car as possible...without getting too deep in the throttle lol.
RichB
Postby RichB » Wed Jun 20, 2012 9:14
Where'd you get your engine work done?
Postby tbot » Sat Jul 07, 2012 9:14
I took my car to Thompson Automotive and let them handle the rest. The actual machine work was outsourced, and I don't remember where. They did an awesome job tho, with 20 over pistons and no balance shaft, the motor runs smoother now than it did before, and I have little to zero piston slap.
The only remaining issue I'm having now is a p0012 CEL, VVT not advancing like it should, which has been a royal pain in the ### since everything that is supposed to cause that code is working properly, i.e. VVT, OCV, oil pressure, timing, sensors on crank and cam...it's rather ####ing annoying.
On a side note, I did get this in the mail the other day :D
Next is a Precision 6031 ;)
Postby erod550 » Sat Jul 07, 2012 9:14
Is that a top-mount mani? Will you have any hood clearance issues with a giant turbo sitting on top?
That it is! And there won't be any issues at all. A guy in NM has a holset hsa35, which is massive, on his 6.
Postby ~Barn~ » Sat Jul 07, 2012 9:14
Ha! That is freaking hard core, 'Bot. Awesome.
Image 720.935.6438
Postby chickenwafer » Sat Jul 07, 2012 9:14
Looking good man, can't wait to see this on the road!
tbot wrote:That it is! And there won't be any issues at all. A guy in NM has a holset hsa35, which is massive, on his 6.
Now, out of all the turbo manufactures, I probably know the least about Holsets, but what is an hsa35? Never heard if it?
Postby Number2 » Sun Jul 08, 2012 9:14
what tsx_guy said.
Congrats buddy! Is it fast?
Operator
Postby Operator » Sun Jul 08, 2012 9:14
Longggggggggggggg time no see man!!! When you come back up north?!?
JL 1000/1 - JL 450/4
[/font]
Current:
RichB
Postby RichB » Thu Jul 19, 2012 9:14
tbot wrote:I took my car to Thompson Automotive and let them handle the rest.
How much did the rebuild run?
Postby tbot » Thu Jul 19, 2012 9:14
It wasn't cheap since I had to replace everything but the block and head. Labor wasn't bad tho, it ran I think $2500.
Car still isn't perfect tho. Having a low oil pressure issue which is causing other problems. I just don't have the money to tear the motor half apart to swap in a new oil pump and vvt. So for the mean time it will sit neglected in the corner.
Postby RX-7 Chris » Fri Jul 20, 2012 9:14
$2500 is actually fairly cheap for the amount of work done.
Postby tbot » Sat Jul 21, 2012 9:14
Oh I know...but with all the parts that I've got into this damn thing, I'm at about $7k...and I have another ~$1500 since we're thinking the oil pump is bad and possibly the VVT, so $700 - $800 in parts and about the same in labor since you have to pull apart the entire front half of the motor.
So when I'm done 100% with everything I want to do, it'll be close to a $11,000 motor build hehe
