My new Rx7 R1
4g63<13b
Postby 4g63<13b » Tue May 29, 2012 9:14
speedjunkie wrote:Are you mentioning this because it's reading vacuum or because it's reading more vacuum than you think it should? I was a little freaked out when my first boost gauge was reading -10 to -20 but over time I realized that's normal lol.
just because it seems to be a pretty low vacuum at idle compared to what iv read
ecam8000
Postby ecam8000 » Tue May 29, 2012 9:14
I used to tune carbs to vacuum at sea level. In those days 20 inches was about as good as it got for a good running piston engine. Come up to this altitude and find 15" is about all you can get.
Eric
2 Fords 29 & 2000.
99 BMW 328i
THANKS! To all who serve.
Postby chickenwafer » Tue May 29, 2012 9:14
I have a mechanical AutoMeter boost gauge, it will read anywhere from -15" at cold start to as low as -10" once warmed up. My engine also has a largish street port, so that will drop your idle vacuum.
4g63<13b
Postby 4g63<13b » Wed May 30, 2012 9:14
chickenwafer wrote:I have a mechanical AutoMeter boost gauge, it will read anywhere from -15" at cold start to as low as -10" once warmed up. My engine also has a largish street port, so that will drop your idle vacuum.
hmmm, ok im not as worried anymore but im reading what you have on a completely stock setup
4g63<13b
would i have to adjust fueling or anything at all tune wise if i removed my double throtle?
Postby chickenwafer » Wed May 30, 2012 9:14
No, you won't need to change anything tune wise.
4g63<13b
Postby 4g63<13b » Mon Jun 04, 2012 9:14
a photo from the event
Postby chickenwafer » Mon Jun 04, 2012 9:14
Legit man!
Postby RX-7 Chris » Mon Jun 04, 2012 9:14
it's so fast the hood fell off.
Postby VRx8 » Mon Jun 04, 2012 9:14
RX-7 Chris wrote:it's so fast the hood fell off.
Lol
looking good
4g63<13b
haha thanks guys! i think i did prettty good for only driving the car for a few weeks, it was my first event ever i loved it! I took my hood off to try and keep temps down, after that event i realize i defiently need suspension and more steering angle haha but it was a great time! car didnt give me a single problem all day im really prowd of it!
4g63<13b
Postby 4g63<13b » Thu Jun 07, 2012 9:14
hey my water temp gauge on my pfc commander every once and a while will go to just 3 lines for a while then eventually come back on and show the temp, also i was wondering how accurate the commander water temp is?
Postby chickenwafer » Thu Jun 07, 2012 9:14
The temp displacy on the commander is very accurate, it reads off the water temp sensor behind the thermostat housing, next to the alternator. If you are having problems I suggest replacing the sensor, it's only around $30 bucks.
4g63<13b
chickenwafer wrote:The temp displacy on the commander is very accurate, it reads off the water temp sensor behind the thermostat housing, next to the alternator. If you are having problems I suggest replacing the sensor, it's only around $30 bucks.
ok sweet thats what i thought i just wanted to make sure, do you think a bad sensor is whats making the commander not read temp some times?
Bad sensor, bad wire connection, or bad connection at the ECU more than likely. It's doubtful the pfc or commander is bad or anything.
