An Accessport doesn't have any impact on whether or not your CDFP can keep up. But with just an intake (TIP and BPV don't have much if any effect on power) you should be fine. Just make sure you have something to monitor your DI fuel pressure with so you can tell if it's dipping below 1600psi at WOT. As long as it's holding above 1600, you're fine.
But yea, the 2nd gens seem to be more sensitive than the 1st gens so definitely monitor it when you start modding.
Oh, and the top mounts for the MS3 and MS6 are identical.
Speed Build
hcbr929rr2
It was good. Could definitely tell the difference with my butt-dyno.
After all was said and done, she was running good. Except for the check engine light because I forgot to plug the O2 sensor back.
BTW the stock exhaust, we got a really clean cut in it too, so whenever your ready for that just give me a holler.
- AuroraAxela
And damn, am I feeling it today.....
worth it though, I learned a few things about you turbo jockeys.
- AuroraAxela
No, it was only after the <cut off> that it was shown that he <edited> which led to the <static>
Mortose wrote:It was good. Could definitely tell the difference with my butt-dyno.
Nice.
When it comes time, I will probably have a welder do flanges so I can bolt it into place and remove it.
Users browsing this forum: No registered users and 92 guests
